DIY: 1998 Volvo V70 Ignition Switch & Cylinder Lock
This topic is in the MVS Volvo Repair Database » DIY 1998 Volvo V70 Ignition Switch & Cylinder Lock Replacement
jzd
Year and Model: 1998 s70 - 388,000
Re: DIY: 1998 Volvo V70 Ignition Switch & Cylinder Lock
Post by jzd »
Full picture of my key
Has thanked: 292 times
Been thanked: 765 times
No chip, guaranteed.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1850 times
Been thanked: 1712 times
+1 with Erik on this. No chip.
jzd
Post by jzd »
Okay, so I got the bolts out of the ignition lock cylinder and the top section is disconnected and out of the car. The bottom section (the one with the key cylinder) is still connected to a blue cable which I think is called the Interlock Cable, but I am not sure. I think that to remove the blue cable the key has to be in position 1 in the ignition. My problem is that my key spins and spins and because the cylinder is broken I can't put it into position 1. Is there another way to remove the blue cable (really the black part of the cable that slides into the ignition cylinder)? I bought a new ignition cylinder from Volvo and would love to install it to see what my next problem is.
Has thanked: 1505 times
Been thanked: 3818 times
Yes, the lock cylinder tumblers do have to make it to key position I to remove that cable
Options, cut it and replace , junkyard part here , I might have one too.
Use the release button as an interim.
jzd
Post by jzd »
Abscate - Thanks for responding. A few questions - what does that cable control, and where does it connect on the other end? It appears to disappear down the steering column (which frightens me). What/where is the release button that you mention?
It connects the gear selector down on the console. It is the interlock that only allows starting in Park or neutral
jzd
Post by jzd »
So you mean to use the release button on the shift console?
Are you aware of any tutorial on how to replace it?
I’ll have a look during airport wait time
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Console removal - as always, patience pays, old plastic is brittle
Another,
Shifter example, this is 850
That should give you an idea how to get in there
