DIY: 1998 Volvo V70 Ignition Switch & Cylinder Lock
DIY 1998 Volvo V70 Ignition Switch & Cylinder Lock Replacement
- Has thanked: 311 times
- Been thanked: 817 times
No chip, guaranteed.
- Has thanked: 2205 times
+1 with Erik on this. No chip.
Okay, so I got the bolts out of the ignition lock cylinder and the top section is disconnected and out of the car. The bottom section (the one with the key cylinder) is still connected to a blue cable which I think is called the Interlock Cable, but I am not sure. I think that to remove the blue cable the key has to be in position 1 in the ignition. My problem is that my key spins and spins and because the cylinder is broken I can't put it into position 1. Is there another way to remove the blue cable (really the black part of the cable that slides into the ignition cylinder)? I bought a new ignition cylinder from Volvo and would love to install it to see what my next problem is.
- Been thanked: 4069 times
Yes, the lock cylinder tumblers do have to make it to key position I to remove that cable
Options, cut it and replace , junkyard part here , I might have one too.
Use the release button as an interim.
Abscate - Thanks for responding. A few questions - what does that cable control, and where does it connect on the other end? It appears to disappear down the steering column (which frightens me). What/where is the release button that you mention?
It connects the gear selector down on the console. It is the interlock that only allows starting in Park or neutral
I’ll have a look during airport wait time
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Console removal - as always, patience pays, old plastic is brittle
Another,
Shifter example, this is 850
That should give you an idea how to get in there
Another,
- 18 Replies
- 15160 Views
Last post by LadieRed
- 4126 Views
Last post by lummert
- 2837 Views
Last post by Mark60
- 1273 Views
Last post by alschnertz
- 1293 Views
Last post by RickHaleParker
