1999 s70 AWD E “Kat” Reina 584953 426Silver [new owner] BerylVolvo
Forum rules
Has thanked: 1609 times
Been thanked: 4064 times
Got the S70 up, installed and module, clamped exhaust , and pushed brake fluid through rear brakes
No start, no crank. Charged battery overnight, started and spun well. 3 year old battery
Bled all brakes except left rear, no fluid push, possible ABS hang up ?
Alternator light is taking revs to go out, will swap in UBG
Thread on installing rock cover plates between body and fuel tank
viewtopic.php?t=99609
Installed fuel line and underneath fuel line cover. Double oetiker 153 clamped the bridge hose
Found I had pinched left brake line torsion arm. Will make up new hard line
Replaced alternator with used but good , brushes worn way down
Clamped ps hose lines
Radiator seep
Link to the fuel tank plates thread, Volvo names them “fuel tank shield”
viewtopic.php?p=595927&hilit=P80+awd+plate#p595927
TestedAC, held overnight, charged with680 gR134A
Achieved 30F delta at 1500 rpm, on fresh air
Cabin filter change
ATF seep at line?
Lower AC M8 bolt loose
viewtopic.php?p=600221#p600221
11 may - Went out early am to run Ekaterina “ The Kat” S70 AWD as she isn’t registered. 1999 of course
She showed 28 mpg on the mpg counter over 10 miles, temperature took a long time to reach 3 o’clock, swishy shell speed noise on right. Nice and smooth acceleration and good power
Got one Side of parking brake in , had bad parts on other
New rear brake pads
Did two Gibbons drain and fill of ATF
31 may. Another 15 mile run, 28 mpg indicated
Replaced earlier grey style ignition switch, electrical with new FCP. Fixed right turn signal not working, and many other ills
viewtopic.php?p=601995#p601995
June 6 m installed lHS parking brake system , completing all inspection items
July 6 new contactless ETB , new plugs , air filter , loomed fuel injection and coil wires
New front rotors and pads by Gochees with FCP parts
New front rotors and VOlvo pads, springs.
Pushed 250 ml fluid each caliper
Order #:
R494135854
July ..ran out of gas, contactlessETM, pinched #2 coil wire , repaired
viewtopic.php?t=100399&hilit=Kat&start=10
6 Sep 145660 Fuel pump failure, replaced with grj444 adapted to case
viewtopic.php?t=100728&start=10
Nice diagram of AAwD fuel pump insert
viewtopic.php?p=596972&hilit=1999+fuel+ ... or#p596972
Documented VC part number below
23 Sep 145770 nySI
4 October 146600
29-30 mpg highway over 1000 miles
added a liter 10W-30 oil
Swapped out thermostat with UBG Caldor? Highway T climbed from 160 to 180F, idle cycle 205-220
Plugged in seat heaters
Topped off brake fluid , check
4Nov replaced right rear upper twilight , Sylvania 67
Switched to Perfo wheels Cont tires front, steel Nokias rear for Fall
14Nov 148600 popped off high pressure fuel line. Repaired at Munch Auto Stony Brook NY
2023 maintenance records placeholder
Jan 1 149001 hard cold start. 5-10 second crank , splutters then runs. Check fuel pressure and ECT specs. Running and warm start all nominal, added one liter oil at last hash mark on stick, topped off brake fluid to full.
Reinstalled fuel fill gaiter 31274302. Much easier to first install into metal rim, then ease fuel filler into the rubber than reverse Metal snap ring retains it.
Really good AWD parts discussion thread on swedespeed by lookforJoe
https://www.swedespeed.com/threads/98-0 ... gs.163864/
June 21 2023 Blew fuel line again
Blew the repaired fuel hose off the junction from the fuel filter...again....
Thanked Kat for taking me 140 miles to Manhattan and back , then failing hose 1/4 mile from garage. Walked home, got P2, got bagels, put in toaster, went back and hard-towed Kat back home
Roughed up NiCopp line, JB weld, and double FI clamped it this time like others. tight access. Used old radiator hose to chafe relief the clamps on the fuel filler neck.
Oil filter change 30 June 150250
Picked up a nail in rear Nokia, retired ftom use, put on Perfo Coopers new front, 5k rear
17bAugust NySI at munch. New rear right brake line, outer front tie rod ends, 4 wheel alignment. 150xxx
Left rear brake line replaced at ???
2024 maintenance records
Mileage 153500
Feb 20 light bub warning. Left rear outer tail is intermittent. Will replace bulb
May 4 climate fan blower inop. Checked fuse 31, cleaned. Motor turning very slowly.
July 4 154007 replaced climate fan (2006 oe) with original (98) from Shagg. Motor bound up. ChargedAC to 43F delta
Top off coolant, 200 ml 154300
5sep nySI at Munch 154800
7DEC 156750
KAT has gone to a new owner and I hope she serves her well.
Long live, nine times, the Kat!
