Nevada1906 1995 850 S60R m56 build thread
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
matthew1 wrote: 11 Apr 2022, 18:11Wow nice!
Thanks!
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Nevada1906
abscate wrote: 11 Apr 2022, 18:13 Get that heat shield on before you drop that into the abyss
For the turbo? I ran the B5234T without a turbo heatshield for 8 years. It worked fine.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
The heat shield is to help keep ambient under-hood temps down, and deflect a little away from the firewall. The turbo won't care one way or the other, but if you have one in decent shape, it can't hurt.
Nevada1906
I'm having a big day. I checked eBay, and it said that my bracket had been delivered. So I went out to the mailbox and there it was.
And now it's on the engine.
This is for an 01-04 nonturbo V70, at least according to the eBay listing. Whatever, all the holes seem to be where they should be. Or close enough. If it works, great. If not, I'll try another one.
Nevada1906
foggydogg wrote: 11 Apr 2022, 20:01 The heat shield is to help keep ambient under-hood temps down, and deflect a little away from the firewall. The turbo won't care one way or the other, but if you have one in decent shape, it can't hurt.
Speaking of firewalls, I'm trying to find the little plastic clips that hold the heat shield to the firewall. No luck so far.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Great progress!
Nevada1906
Chopped the downpipe off the exhaust.
And now I have a question: Is this bracket necessary?
It goes between the subframe and the steering rack. I was digging through my parts pile when I found it and realized I'd forgotten about it. However, I've noticed that a lot of guys do steering rack or sway bar work on their cars and don't even have the bracket at all, so does it even need to go back in?
bmdubya1198
I hadn't had this bracket installed on my car for a while. It wasn't until I noticed it was there on my parts car that I reinstalled the bracket. Only reason I did was because I replaced the rack, I probably wouldn't pull it apart otherwise.
I don't think it's too necessary.
Nevada1906
bmdubya1198 wrote: 14 Apr 2022, 21:17 I hadn't had this bracket installed on my car for a while. It wasn't until I noticed it was there on my parts car that I reinstalled the bracket. Only reason I did was because I replaced the rack, I probably wouldn't pull it apart otherwise.
I thought it over and reinstalled it, as it was there in the car before I took everything apart. However, while it looks like a support for the steering rack (which, brilliantly, supports the back of the engine. Nice job there, Volvo.) it doesn't seem to actually TOUCH the rack.
Oh well. It won't hurt anything to be there.
bmdubya1198
Better to have it in place! My OCD requires me to have everything where it belongs, so I always feel better knowing that everything is installed properly.
