2015 S60 MAP sensor location
tflesui
Year and Model: 2015.5 S60 T6 Platin
Post by tflesui »
Greetings!
Need some assistance as I've not been able to find any straightforward answer anywhere else.. My CEL came on the other day and codes P0108 & P0106 were present. After clearing the codes P0106 has remained and my first thought is to try and clean the MAP sensor.
I cannot, for the life of me, determine whether my 2015.5 T6 4cyl Platinum has a MAP sensor and/or where it might be located. Has anyone found a MAP sensor on this year/trim and had success trying to clean it? Any help would be greatly appreciated, thank you
2015.5 S60 T6 Platinum
2002 S60 T6
2000 S40
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Location of MAP sensor on intake manifold.
Pos. # 5
Source: https://parts.volvocarslisle.com/showAs ... ly=7468356
I would also inspect the electrical connector and then have a look at the PCV Breather (oil trap box) just for good measure.
Hope this helps :D
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
tflesui
Post by tflesui »
@regent,
This is a huge help! Thank you! I've been driving around with the CEL on for about a week and a half and I commute ~80 miles to work (each way) so getting this taken care of will account for much peace of mind. Thank you again and I'll report back when I get this looked at. πŸ™πŸ½
2002 S60 T6
2000 S40
tflesui
Post by tflesui »
Been a while but I wanted to give an update now that this issue has been resolved. Thanks to @regent for help with the diagram. I was able to locate the MAP sensor and attempted to clean it but I was not able to clear the CEL. I ended up purchasing a new
MAP sensor from FCP Euro and swapped them out fairly quickly. After doing so, CEL is gone! I've added some pictures for anyone else who may need assistance.
2002 S60 T6
2000 S40
