2002 S60 high fuel pressure
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
In refrigeration, if you have a kink or obstruction in the line, it can cause your pressure to go way out of spec, since the compressor is dead-heading.
Does this same theory possibly apply to this fluid pump? Could it possibly be a fuel line kinked or some contamination got into a hose somewhere? Perhaps you should try and drain and clean or replace your fuel filter.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
wrgallant
- Year and Model: 2002 s60
- Been thanked: 2 times
I figured it out - a previous owner replaced the fuel line from the pump to the fuel filter. When they did, they eliminated the T that feeds back to the return port on the pump. I added a T after the fuel filter back to the return port. Now when pressure gets above 50, the regulator inside the pump dumps fuel back to the pump.vtl wrote: 18 May 2022, 10:53 The theory is you put a PEM-controlled pump into your older car that does not have a PEM.
ECM tells the PEM how much load is required for the pump, PEM adjusts its PWM duty cycle, the pump develops fuel pressure accordingly.
When PWM line is connected to constant +12V, the pump thinks 100% load is required and works hard, until an internal pressure relief valve is triggered, which happens at about 100 PSI. I remember seeing that number when ECM cuts the fuel sharply right on fuel injectors, and the pressure raises momentarily to about 100 PSI.
Thanks for helping me understand the system
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Huh... Good huntingwrgallant wrote: 23 May 2022, 06:26 I figured it out - a previous owner replaced the fuel line from the pump to the fuel filter. When they did, they eliminated the T that feeds back to the return port on the pump. I added a T after the fuel filter back to the return port. Now when pressure gets above 50, the regulator inside the pump dumps fuel back to the pump.
Well done figuring out an undocumented unsupported fix, known as a Charlie Foxtrotwrgallant wrote: 23 May 2022, 06:26I figured it out - a previous owner replaced the fuel line from the pump to the fuel filter. When they did, they eliminated the T that feeds back to the return port on the pump. I added a T after the fuel filter back to the return port. Now when pressure gets above 50, the regulator inside the pump dumps fuel back to the pump.vtl wrote: 18 May 2022, 10:53 The theory is you put a PEM-controlled pump into your older car that does not have a PEM.
- 16177 Views
Last post by Richard99
- 685 Views
Last post by v70XCSteve
- 814 Views
Last post by 93Regina
- 667 Views
Last post by oragex
- 34 Replies
- 8693 Views
Last post by vtl
