Ac evaporator large leak
Has thanked: 1609 times
Been thanked: 4065 times
misha wrote: 16 Jul 2022, 08:24 This far i could only find 20x2.0mm and 20x3.0mm.
O ring master thread says 20x2.3mm for heater core o rings.
Will dig some more.
300 microns of width difference wont alter function. 20x2 will seal fine. I didnt report the error when i made those measurements either.
Sometimes Skandix in Germany reports actual o-ring sizes so maybe put that part number into their engine and see what it says?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Tried that allready....no measurements data.
Can green...ac system 20x2.0 o ring be used on a heater core pipes or i need black ones?
Edit...
I asked my ac specialist and he said that i should not use ac o rings for heater core pipes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
This is a big job but I did it over the course of a day. It's doable. I even pumped it down and recharged myself. Years later still going cold, although my clutch on my ac condenser is going bad.
1995 850 GLT Wagon w/ 200,000 miles
You can use AC orings, which are HNBR material, in standard applications but not the reverse.
The”h’ makes them more resistant to the refrigerant and oil inthe AC
misha
Post by misha »
He will check if he have the ones i need...i sent him a picture of o ring you posted here.
Still waiting for evaporator price and availability.
Volvo part # 3545586 doesn't show anything at most car parts shop.
Volvo dealer responded today and said that they don't have them in stock but can arrive in 15(working)days.
I guess that i'll need to wait for it since i have no other choice.. unless my ac specialist finds them for me.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I can beat the Volvo dealer, but you have to host me on my next visit….
misha
Post by misha »
:lol:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Nissens Ac evaporator and heater matrix ordered today.
Evaporator should arrive in Monday and heater matrix in about two weeks since they don't have it in stock currently.
I thought it's a good idea to replace the matrix too since whole dashboard needs to come out anyway and it's still original.
Allready got volvo o rings from dealership for heater matrix(last year :oops: ) and i wonder if they are needed with Nissens.
I just didn't had time to complete this job last summer...but not having working ac in 45 degrees Celsius weather is insane.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Not fun at all. :shock:
Dashboard removed,tommorrow HVAC system should be removed to replace evaporator and heater core and to sort out aftermarket alarm system siren.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Don’t be afraid to Dremel off the evaporator snouts rather than fighting the springs.
Much easier to remove short snout piece on bench.
Warning. The hard pipe goes deep into the evap so make sure you cut as close to firewall as you csn
