2003 S60 256K miles. Original owner. The car seems to drive fine but I can't believe my struts are still doing the job like they should.
Thoughts?
Thanks,
Bob
Southport, NC
When to Replace Struts?
Fishheadbarandgrill
- Year and Model: S60, 2003
- Has thanked: 2655 times
- Been thanked: 1248 times
Well, the Classic method used for decades on cars of every type is this: push down on the bumper, front and rear. If it comes straight back up, they're good. If it bounces a bit, they're bad.
That's a lot of miles for the original struts, but not unheard of.
deano1
- Year and Model: 2001 s60 1999 awd
- Has thanked: 13 times
- Been thanked: 16 times
If the car seems to be in good control in turns when experiencing rough or uneven pavement that's a good sign they're still doing the job they were intended for.
But that upper bearing will get stiff and start making noise over time and could definitely use lubrication.
Plus if you're in the rust belt, the upper spring seat will deteriorate and could fail, that could be catastrophic if it happens when driving so
whole strut assembly should be inspected just as a matter of good maintenance.
Cheers Dean
Cheers Dean
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
All preference (well safety too) on how much bounce squeaks and rattles you can put up with.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 1505 times
- Been thanked: 3818 times
My favourite before/after strut photo is here…..
- E35943E8-BCDC-4D41-A4EE-3E248840E1C7.png (2.99 MiB) Viewed 508 times
- Krons
Why would you batter and deep fry your struts?
I bet they tasted terrible, even with the "extra crispy" recipe.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 292 times
- Been thanked: 765 times
Which one is before?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
