2003 S60 256K miles. Original owner. The car seems to drive fine but I can't believe my struts are still doing the job like they should.
Thoughts?
Thanks,
Bob
Southport, NC
When to Replace Struts?
- Has thanked: 2864 times
- Been thanked: 1332 times
Well, the Classic method used for decades on cars of every type is this: push down on the bumper, front and rear. If it comes straight back up, they're good. If it bounces a bit, they're bad.
That's a lot of miles for the original struts, but not unheard of.
deano1
- Year and Model: 2001 s60 1999 awd
- Has thanked: 13 times
- Been thanked: 17 times
If the car seems to be in good control in turns when experiencing rough or uneven pavement that's a good sign they're still doing the job they were intended for.
But that upper bearing will get stiff and start making noise over time and could definitely use lubrication.
Plus if you're in the rust belt, the upper spring seat will deteriorate and could fail, that could be catastrophic if it happens when driving so
whole strut assembly should be inspected just as a matter of good maintenance.
Cheers Dean
Cheers Dean
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
All preference (well safety too) on how much bounce squeaks and rattles you can put up with.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 1611 times
- Been thanked: 4074 times
My favourite before/after strut photo is here…..
- Krons
Why would you batter and deep fry your struts?
I bet they tasted terrible, even with the "extra crispy" recipe.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 312 times
- Been thanked: 818 times
Which one is before?
- 1481 Views
Last post by erikv11
- 1994 Views
Last post by EB53
- 1221 Views
Last post by volvostud
- 615 Views
Last post by E Showell
- 2072 Views
Last post by pierremcalpine
