Thread to document where to cut at right rear seat to get to main fuel pump
Robert video link for v70, slightly different
1999 s70 awd Kat fuel pump by hole, no wait, tank drop, no wait , axle drop
- Has thanked: 1498 times
- Been thanked: 3810 times
- A1CD4B80-3FCA-4E82-BBF9-8E8A733E0BD9.png (2.76 MiB) Viewed 2080 times
- 1DCB50DC-19A6-4D13-A60F-92B61E5A3967.png (3.01 MiB) Viewed 2080 times
S70 does not have the rear seat catch like the v70
- 2492E356-0E6F-4C54-994C-A644E5B9248C.jpeg (755.99 KiB) Viewed 2067 times
The S70 floor plan is different than the v70 bit lots of good info here , including cross reference to aftermarket pumps!
viewtopic.php?t=20367
Oh oh oh oh ….
by jimmy57 » 31 Oct 2011, 12:00
850 AWD is exactly the same.
I have replaced 3 tank pumps on Gen 1 XC70's lately and I do a partial drop of tank without lowering suspension.
You remove the RH trailing arm with its forward bracket, disconnect driveshaft from VC, take VC together with its housing off the rear diff (mark the flange so it can be put back where found), remove access cover and undo the connectors, and then take off straps and let RH side of tank down. Oh, take off the exhaust pipe from catalyst to the muffler pipe over LH wheel driveshaft.
No need to cut hole in floor, wire routing is easy, and tank is down far enough for sending unit to go in and out with no trouble.
The VC flange has 6 8mm inhex bolts and the housing is held to diff with four 14mm head bolts.
The hardest part of the whole job is getting the fittings to unlatch on the sender. I used a tool meant to depress the collar on those fittings and bent it to work down in the hole but it still was a pain.
- Has thanked: 1836 times
- Been thanked: 1709 times
Wow! That is even easier than the video I was trying to find. Other than the removal of the muffler and VC unit that is not too bad. Easier than on a wagon too as you don't have to remove the trunk area flooring panels to get to the cover plate.
When undoing the bolts on the VC unit to the rear diff, I used a long extension rod to get to the bolts both for undoing and torquing them back up.
Not sure on the reference for the 850 AWD? Does he mean the fuel pump is the same or the process? The pump is also listed as NLA
Good Luck!
Good Luck!
I’ll be partial tank dropping Monday night. I’ll take pictures on the S70 to documemt
Can someone with VIDA see if there is a fuel tank drop proCedure for Awd ?
P OST up please
P OST up please
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Third round trip for some of those fasteners ?
At least nothing will be un-Godly stuck this time.
There is a procedure for it, but it includes the full rear subframe and tank drop. I may have it on my PC. I will look later and post it.
I found it in all data
