When you say " super16T ", is that the set up with the 11 blade turbine ?Goupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
Overflowed the MAF, bent some rods, overflowed the injectors, started knocking again![]()
More power out of b5254t(this has been done too many times I know) Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
1999 V70 GLT
1999 V70 GLT
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Nope, that's why it took us (me and the tuner, aaron from Vast) and the engine by surprise.Sveedy wrote: 25 Aug 2022, 14:25When you say " super16T ", is that the set up with the 11 blade turbine ?Goupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
It's an old stock aftermarket turbo, the CHRA has been replaced by a 300$ OE type one and the hot side is an angled flange from a volvo 13t (not even the bigger one).
Nothing in this was supposed to perform more than any oem 16T, yet it does
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Petskoi
- Year and Model: 1997 V70 awd
NiceGoupil wrote: 25 Aug 2022, 13:58the bent rods were from me not looking at the data, doing a pull for logs, ran out of MAF unexpectedly so it was running super leanPetskoi wrote: 25 Aug 2022, 13:46The bent rods might be indicating too much boost too low at the rev range. I remember something like it needs to be ~0.7 bars under 3k rpm. Take this with a grain of salt tho, its a "trust me bro" statementGoupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
The second time it started knocking makes no sense, there isnt anything wrong in the datalogI'm replacing the knock sensors and installing an oil pressure gauge this time (+ some H beam rods and new bearings)
Petskoi
Well it is true, that a 13t flows actually better than even a 15g. I was counting some hp numbers with different psi's using the compressor maps for 13t, 15g, 16t etc. Thought I was counting wrong, checked many times then gave up and used an online calculator and it gave me same numbersGoupil wrote: 25 Aug 2022, 14:43Nope, that's why it took us (me and the tuner, aaron from Vast) and the engine by surprise.Sveedy wrote: 25 Aug 2022, 14:25When you say " super16T ", is that the set up with the 11 blade turbine ?Goupil wrote: 25 Aug 2022, 11:26 I'm in the process of doing this, but it's not going well because I have somehow built a super16T that flows as much as a 20T![]()
Nothing in this was supposed to perform more than any oem 16T, yet it does![]()
Petskoi
I was just wondering is it safe to drive the car to the tuning shop, after installing bigger injectors, the new turbo and the japanifold? The stock tune should limit the boost so that it doesnt lean out right?
- Goupil
I would say it will probably run richer more than anything due to the bigger injectors. Is it a long drive? If you can, keep it out of boost as much as you can and it should be fine
Petskoi
Ya, thats what I thought(try to keep out of boost/running rich) well the drive is 60km so... 40 Miles? Give or takeGoupil wrote: 25 Aug 2022, 22:44 I would say it will probably run richer more than anything due to the bigger injectors. Is it a long drive? If you can, keep it out of boost as much as you can and it should be fine
- 806 Views
Last post by - Pete -
- 10 Replies
- 1331 Views
Last post by 454cid
- 30 Replies
- 10085 Views
Last post by hmsky83
- 1804 Views
Last post by precopster
- 22 Replies
- 1918 Views
