I need ABS idoscilloscope wrote: 05 Nov 2022, 15:16I can already decrypt the eeprom. I need a synchronisation.rkam wrote: 05 Nov 2022, 15:05 Here is an attempt on decrypting the eeprom.
out.rar
45 61 80
26 08 16 54 70 79
Vida CEM swapping
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
oscilloscope
- Has thanked: 27 times
- Been thanked: 11 times
As far as i know Abs id is not required for cem L or HDudde wrote: 07 Nov 2022, 14:54I need ABS idoscilloscope wrote: 05 Nov 2022, 15:16I can already decrypt the eeprom. I need a synchronisation.rkam wrote: 05 Nov 2022, 15:05 Here is an attempt on decrypting the eeprom.
out.rar
45 61 80
26 08 16 54 70 79
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
If you tell by phone about "this" case and forum topic, price for this option is $150 for you. If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.oscilloscope wrote: 04 Nov 2022, 00:34Yes I have herd of them , from what I remember there very exspensive. , although at this current time It wouldn't load on my phone. So I couldn't confirm if its the same price.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
oscilloscope
At the time I couldn't see the fee on there site as it wouldnt load correctly. , and that price out ways the cost of the job., by way off. I have considered purchasing DiCEyagger wrote: 08 Nov 2022, 11:50If you tell by phone about "this" case and forum topic, price for this option is $150 for you. If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.oscilloscope wrote: 04 Nov 2022, 00:34Yes I have herd of them , from what I remember there very exspensive. , although at this current time It wouldn't load on my phone. So I couldn't confirm if its the same price.
- RickHaleParker
- Been thanked: 980 times
If VIDA is not installed on the remote machine, is DiCE the only J2534 interface you can work with over the internet?yagger wrote: 08 Nov 2022, 11:50 If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.
Active
Past
Past
- DJGlock
- Year and Model: 2007 XC70
- Has thanked: 5 times
Dear T5LukeT5Luke wrote: 04 Sep 2022, 02:39 Sorry was 50 downloads only, here are both again...
Also Windows 10 doesn't notice me about anything, maybe it is location based on 3 computers i get nothing. Maybe defender in US sees something problematic in this code...
I tried to use UDSTool Crack to get PIN for my XC70, but got the following issue.
Car: XC70 2007, YV1SZ595771286825
Dice: Chinese clone, but works good (as per my experience).
Repro steps:
The car stayed for a day, I just opened it, connected DICE and run your tool. Did not touch ignition lock at all (so it was in position 0).
It tried to start the process, but failed (log below).
Repeated several times - no luck. Had a small conversation with vtl, he advised to ask for help here.
Does the response from CEM tells you anything useful? Vtl told me that it looks like one of modules did not enter sleeping mode and hence the response was bad. Any ideas how to fix it? May be you have any other build with extended logging?
- yagger
VIDA not need. DiCE is required.RickHaleParker wrote: 09 Nov 2022, 02:16If VIDA is not installed on the remote machine, is DiCE the only J2534 interface you can work with over the internet?yagger wrote: 08 Nov 2022, 11:50 If you have a DiCE it is possible to do everything via Internet. If you do not have a DiCE also need to pay for shipping.
NuovoRecord
- Year and Model: 2004 V70
Are there any tricks to soldering to these ECU pins? I just had a hell of a day trying to get wires connected. The pads seem to lift at the slightest movement.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
30AWG copper wire w/ silicone insulation, regulated soldering iron/station.NuovoRecord wrote: 20 Nov 2022, 19:26 Are there any tricks to soldering to these ECU pins? I just had a hell of a day trying to get wires connected. The pads seem to lift at the slightest movement.
NuovoRecord
I managed to brick my CEM. Be careful.
- 9355 Views
Last post by RickHaleParker
- 9346 Views
- 27 Replies
- 28939 Views
Last post by cn90
- 10 Replies
- 10860 Views
Last post by jonesg
- 5975 Views
