Using all the parts that Volvo put on the car helps with questions like....
Funny the car started on two occasions now after the no-start incident.
So how in the world can i ever get this car to be reliable?
Oh ok i'll make sure i install it then.abscate wrote: ↑21 Jan 2023, 01:39 The engine runs better with a temperature regulated input air flow. In cold , wet weather around town, the throttle body can ice up, having experienced that once, it was unpleasant
So how in the world can i ever get this car to be reliable?![]()
Code: Select all
short joining coupler pipe installed over that pipe end:
[font=Courier New]
all three connected together:
-------- ------------------------------------------------ [air box end]
It is generic, but FCP Euro said it fit this car.
I dont have any problem getting it off. This is about getting a new part on.wizechatmgr wrote: ↑22 Jan 2023, 14:27 Typically the flexible hose that I like to call the dryer hose, will be able to be easily removed. It's a friction fit. When it isn't tight it can make a heck of a racket. The one I got from FCP to replace was really good quality, the best I've ever had. There was more than enough so a left over length was also used on an older VW Van.
If you're in cold weather, I'd consider it necessary unless you have a garage or a block heater.
Hi,
