Problem with SRS module
rexma1301
- Year and Model: 2006 V70
- Has thanked: 2 times
I have a problem with these fault codes. I tried to solve the problem by replacing the seats but fault codes are still present and cannot be cleared. I bought the car with an SRS error on the display, and I assume it has been in a crash. I doubt the SRS remembered the Crash code... Can I replace the SRS module with one from another car, same model/same year? Or maybe there is another solution?
- 20221118_202732.jpg (504.71 KiB) Viewed 607 times
- Has thanked: 1502 times
- Been thanked: 3817 times
See the recent thread on Carprog, guys in Lithuania
rexma1301
I tried another module, but again I get fault codes that cannot be erased even if all the numbers match.
- 20221122_161620.png (4.3 MiB) Viewed 528 times
- 20221122_152853.jpg (218.83 KiB) Viewed 528 times
rexma1301
After clearing the airbag crash data, errors still appear among them and some new ones. I don't know what could be the problem, and where to start with solving it.
- 20230125_191417.jpg (491.47 KiB) Viewed 472 times
- Has thanked: 927 times
- Been thanked: 1000 times
Not all code readers can erase SRS codes. Other threads have addressed this and readers that will clear the SRS codes.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
there was a similar problem posted here not too many weeks ago.
the faults are not completely erased, they're actually stored or archived in the main computer ,
Once you hit the max number of clearances it no longer erases the SRS code.
there some sort of reader or software that can delete it.
Its not vida. The answer is here but you'll need to search for it unless someone can remember what it was.
I only read about it for casual reference. But I know that it works.
- jonesg
You can mssg doubebug directly if no-one has an answer for you.
He's a volvo software specialist.
memberlist.php?mode=viewprofile&u=57962
He is also here,
https://www.datatransferring.com/volvo
He is also here,
