Mk2 B5254t3 and n/a cams?
Karpov
Year and Model: V70 mk2 2000
Post by Karpov »
Hello
Is somebody installed N/A camshafts to these "newer" T5 engins with VVT?
At 850 that is common.
Is it possible?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I believe some have done it, yes.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Very unlikely that is going to work. The seals, etc are different on the pulley side of things. AT least not without a bunch of custom machining work.
Also, I don't think there is much, if any gain in lift, etc.
The stock Volvo 850 turbo cams are pretty anemic, which is why the NA cams help there. The later RN cams are nowhere near as bad.
(There is a comparison of some of the cams on VolvoSpeed, but the forum is all screwed up and the search isn't working.)
Karpov
Post by Karpov »
Okay... And you mean same age N/A engines? Thats maybe reason that there is very little info about that swap.
dikidera
Post by dikidera »
viewtopic.php?t=82237
https://www.swedespeed.com/threads/cam-swap.155521/
However now that I notice the t3 is the Ford changed version, right? Perhaps they introduced changes which makes this swap not as easy.
Chuck W
Post by Chuck W »
Ah, yeah. You would want to look at the cam specs and check the seals, etc on the pulley end before you would want to move forward.
I have some of the cam specs from the B5244T3 and the P2R cams at home (01-02 LPT RN engine), but nothing later.
Karpov
Post by Karpov »
My engine is MY2000 (first 2gen v70) no ford inside :mrgreen:
