Axle is stuck:( Topic is solved
- chrafael
- Year and Model: 1998 v70 GLT
- Been thanked: 10 times
Re: Axle is stuck:(
It's wrong by any seal I've ever changed. Spring loaded rubber goes to the inside.
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 14 times
When I took out the old seal, the spring came off even before the seal budged from its location.
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Then again it may have popped out as I was trying to get the seal out.
5rivers
5rivers
Ok, so if the seal was put wrong, how do I extract the axle?
5rivers
- Has thanked: 1850 times
- Been thanked: 1710 times
Cold chisel between the trans case and the axle flange. As it is not fully home then you may have to fit a piece of wood on the trans side and then use the chisel as a wedge to try to force it out. Careful not to damage the seal recess.
From what I can see your seal is fitted correctly. Flat face outward? Not sure what the other guys are seeing that I am missing. Oops retract that, I now see the little piece of spring wire. The seal is as per the picture below. The metal face of the seal should be out.
- chrafael
I changed this seal about six years ago, still dry. The circlip may damage the seal on the way out. Good luck. You probably will have to remove the axle again. I wouldn't beat on the carrier bearing
any way.
any way.
5rivers
I finally got the axle out!! Hooray
5rivers
- Has thanked: 1505 times
- Been thanked: 3818 times
The carrier bearing bolts are removed, right Kally? Two 12mm hex head m8 bolts and then pop off the semicircle metal part. Then snap the axle out of the other half and give it a good tug
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
Seal looks backwards to me too.
But even if backwards should not prevent the shaft from coming out.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
5rivers
Thanks for all your replies and help!
I did remove the bolts on the carrier bearing and used a piece of wood to tap gently against the metal part of the bearing. The axle eventually came out. I released the boot clamps and moved the boot off the outer part of the axle and it fell off! The cir-clip was not fully engaged! Am working now on getting the boot back on.
5rivers
- 470 Views
Last post by Blacklab467
- 21 Replies
- 4532 Views
Last post by mecheng
