Identify this part - fuel system?
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Blacklab467 wrote: 08 Dec 2023, 08:03 I was going to comment on the wiring routing around the top of the radiator on the previous picture but I see you've gotten it sorted out in the subsequent photo. Beautiful car and engine bay!
All the clips for the loom onto the fan cowl were destroyed by some ham-fisted garage monkey. I manages to buy 'fir tree cable ties' last week and it's now all tidied and back to factory stage zero :)
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Would you mind taking a couple detailed photos of how and where the wiring attaches to the shroud? Mine's incorrect and I can't tell for sure exactly how its supposed to go, also I have some clips on the headlight wiring loom that are supposed to affix the wiring to flat sheet metal and Im not sure where they are supposed to attach, thanks.
2003 XC 70 (sold)
P80GLT
Post by P80GLT »
Not sure my pictures will be much help
This is an eBay image to show the position of the holes
All red arrows are where the cooling fan harness is clipped into.
All yellow arrows are for the alternator A/C harness (I presume that's where the wires go!!!)
I'm not sure if there should be a fir tree clip where the blue arrow is, I feel it would throw the line of the cable out a bit so I just used a plain cable tie for that hole
Headlamp connections clip onto the top plastic of the headlamp backing
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Blacklab467
Excellent, thank you!
2003 XC 70 (sold)
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Post by weitau »
P80GLT wrote: 07 Dec 2023, 10:17 It's the switch for the brake vacuum pump part number 31400692 and yes it's in the correct location
Thanks for the PN! I did find my part from the salvage yard for less than $20.
2004 V70 2.4L
P80GLT
Post by P80GLT »
weitau wrote: 08 Dec 2023, 22:10 Thanks for the PN! I did find my part from the salvage yard for less than $20.
Have you checked the vacuum pump is working?
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1609 times
Been thanked: 4065 times
Don’t forget to zip tie your new / old part!
weitau
Post by weitau »
P80GLT wrote: 09 Dec 2023, 03:23
To be honest, I haven't tested the pump yet because the brakes seem to be fine, and another emergency came up. After 3000 miles, there was only a drop of oil on the dipstick :o . I've never had oil burning issues before, but I've refilled with fresh oil and 600 miles later, the oil level has been steady. I'm kicking myself for letting it go so long before checking, but all other indications (fuel consumption, vibrations, etc) are fine. I'll give it another oil change and maybe an engine flush in the next 200 miles. The weather has been awful here back in NY (cold and rainy) and I can only work on the car outdoors.
2004 V70 2.4L
If you still had oil on the dipstick, even just the tip, it’s fine. Keep it between the hash marks but no worries about getting a bit low in the crankcase, no damage done.
Im downstate on Long Island mostly , with biweekly Trips up to Albany
weitau
Post by weitau »
abscate wrote: 18 Dec 2023, 04:42 If you still had oil on the dipstick, even just the tip, it’s fine. Keep it between the hash marks but no worries about getting a bit low in the crankcase, no damage done.
Thanks! that's reassuring. Another thing, which may not be so important, is that it takes about 10 minutes of driving before the engine temp gauge gets to half way to normal operating. That's today at 33 degrees. Maybe the thermostat is stuck open? the quicker the engine reaches normal operating temps, the better.
2004 V70 2.4L
