1996 850R p0112
Texasbrainstew
Year and Model: 1996 850 R
Re: 1996 850R p0112
Post by Texasbrainstew »
Yessir! And yessir I know, I just removed it myself and rebuilt a b5234t from a 95 turbo wagon and slapped it in there
npexcept
Year and Model: XC90 I D5 (275) 2003
Has thanked: 9 times
Been thanked: 23 times
Post by npexcept »
Couldnt find any useful infos in vida yet. Just tells for checking the wiring if the sensor in the bumper is okay. (see picture below, not much infos)
What manufacturer is printed on your MAF sensor? Bosch?
Just because you're trash, doesn't mean you can't do great things.
It's called garbage can, not garbage can not.
Texasbrainstew
Yessir Bosch
npexcept
Post by npexcept »
Okay, the Bosch variant has no built in temperature probe from what I've read.
So I guess, the fault is somewhere in the wiring from the sensor at the bumper to the ECU (?).
The sensor maybe lead to the ECC instead (located under the dashboard).
Maybe there is some connector loose. But at this point I'm just guessing.
I'm under 30, you dont have to call me Sir lol
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Wierd.
What is actual ambient temperature reading on board computer display?
Is it the same -40F like ecu sees it?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
npexcept
Post by npexcept »
misha wrote: 01 Feb 2024, 03:31 Wierd.
Texasbrainstew wrote: 31 Jan 2024, 13:56 Dang ECU is now reading that the ambient air temp sensor is showing -40°f.
My instrument cluster is reading the temperature correctly.
Texasbrainstew
Man Im just about to finish my 30th year dont say that lmfao.
Sorry I got caught up in some stuff yesterday.
I checked all wires and grounds again just to be sure nothing is getting pinched or anything.
On the sensor and cluster note, when I pulled the sensor out with the car running the cluster read LO as it should. Just another way I tested to rule things out.
Is there any way you could send me a key for the wiring diagram picture! I'd like to see whatsup with those!
Texasbrainstew
Mainly curious as to what 23/306 is and 4/30 on the diagrams you sent. The rest I'm assuming are pins?
Texasbrainstew
Wanted to also mention I payed attention to the ecc and I have no flashing lights when I start on the recirculation and ac buttons
misha
Post by misha »
At this point...i would remove negative battery cable for couple of minutes and re-seat ecu while battery is disconnected.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
