[V70, 1999, 2.5 TDI] Air Conditioning - Compressor does not run
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
No....on the passenger's side....where evaporator pipes goes through firewall....there is a pressostat with 2pin connector... on thicker(low pressure) line.
High pressure line is behind passenger's side headlight and it's a 3 pin connector and switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MichaelPL
Year and Model: S70, V70
Has thanked: 2 times
Post by MichaelPL »
misha wrote: 09 Sep 2024, 13:46 No....on the passenger's side....where evaporator pipes goes through firewall....there is a pressostat with 2pin connector... on thicker(low pressure) line.
Now I understand what you're referring to.
I'll check it and let you know. Unfortunately, this would mean that there is an undetected leak somewhere :oops:
Volvo S70 SE 1998 2.5 20V 170 KM Aqua Blue Metallic
Volvo S70 1997 2.5T 193 KM Mystic Silver Metallic
Volvo V70 1999 2.5 TDI 140 KM Graphite gray metallic
FSC Żuk 1990 2.4D :mrgreen:
Polski Fiat 125p 1974 :mrgreen:
misha
Post by misha »
Evaporator is a weak point on ac system in these cars(p80) because of HVAC system design.
At this age almost all of them already needs to be replaced.
P2 cars don't have this problem.
I replaced mine last year and that was a 3 day job.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MichaelPL
Post by MichaelPL »
That's exactly what I'm worried about :shock:
I looked up a tutorial on how it's done, and I'm not surprised it took three days....
misha
Post by misha »
It's not a hard job,but it's a BIG job and time consuming.
When i was reading a "how to" and what needed to be removed....i didn't felt very well.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MichaelPL
Post by MichaelPL »
There's definitely a lot of work involved with that. It's the kind of job that takes time rather than being particularly difficult.
I checked one more thing yesterday. I connected a gauge to the air conditioning service port, but the compressor was off, and the reading was at 120 PSI.
misha
Post by misha »
For ac pressure check you will need ac professional gauges...regular gauge will not work for this.
And...pressure is always checked when compressor is running.
Why did you replaced compressor?
Was it seized or leaking?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MichaelPL
Post by MichaelPL »
misha wrote: 09 Sep 2024, 14:20 For ac pressure check you will need ac professional gauges...regular gauge will not work for this.
I actually have a Jonnesway gauge set. But you're absolutely right—the result here can be misleading.
misha
Post by misha »
Is there still 120 psi pressure in the system?
Why the compressor was replaced in 1st place?
Seized or leaking?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MichaelPL
Post by MichaelPL »
Yes, there is still 120psi.
The whole failure started with the compressor seizing. There were visible leaks from it and the air conditioning radiator. A complete new set was installed, including the compressor, radiator, dryer filter, and replacement of the O-rings.
The entire system was flushed clean. The expansion valve was also replaced.
