04 XC70 front wheel scrubbing, tight turns
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I believe your ‘04 has the steering stop tabs on the control arms, have you had a look at the condition of those? Another item of note, my car did exactly what you are describing several years ago, I put up a similar post to yours inquiring what it could be. This was resolved with new tires which made a huge difference in the scrubbing at near lock steering radius in parking lot situations, my tires looked similar to yours and were just over an inch short in height from Volvo spec ( no name 215/65/16’s ). New Toyo’s of the correct size resolved the scrubbing which was a bit of a surprise to me. At the time my car had all brand new suspension and steering components blue box Volvo. Have the alignment tech do a thorough inspection on the front end paying particular attention to the strut spring seats.
2003 XC 70 (sold)
- Blacklab467
Here’s a link to my query a few years ago
viewtopic.php?p=558091#p558091
2003 XC 70 (sold)
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
New windshield tomorrow, alignment next week.
Since I was going to get new summer tires in the spring, One could argue I should just order them now and get it over with....
- BlackBart
Good question - I will check on these.Blacklab467 wrote: 10 Sep 2024, 20:31 I believe your ‘04 has the steering stop tabs on the control arms, have you had a look at the condition of those?
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
If you have them, switch them to the other's side and flip them upside down to double their life magically... VOLVO doesn't want you knowing about this secret trick!!!BlackBart wrote: 11 Sep 2024, 14:06Good question - I will check on these.Blacklab467 wrote: 10 Sep 2024, 20:31 I believe your ‘04 has the steering stop tabs on the control arms, have you had a look at the condition of those?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
I crawled under. I'm not seeing anything resembling a steering stop here. Didn't I have them on my 850 - like a white nylon stop bolted on the side?
LF from the rear
LF from the front
These are the aluminum IPD HD control arms.
LF from the rear
LF from the front
- br0dy519
No steering stops present from that pic. I only have them on my S60.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
Well here's a stupid thing I did -
When I went out to check the tire ages, I looked at the age on the fronts, checked the backs, and noted Hankook - on the backs. The fronts are some no-name "Arizonian" things I've never heard of. The backs are in decent shape with some tread left. D'OH.
- Has thanked: 987 times
- Been thanked: 1075 times
I too need a new set of tires soon. Front edges are thin and weather cracking is appearing. I plan to replace in a few weeks. I have been airing up a slow leaker forever.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I’d check for snow before your trip. Those tires perform ok in wet weather?BlackBart wrote: 10 Sep 2024, 13:45 OK.....let's talk about 10 yr old tires... 25th and 26th week of 2014. Hmm. Hankook all-seasons, 215/65-16 96T. These came on a spare set of alloy wheels I bought for snow tires. The seller was supposed to take them off but shipped them mounted. They weren't bad so I decided to use them up. I also had a set of Michelins with even less tread, and even older, so I tossed them. These looked fine when I put them on in the spring.
We have an 1800 mile trip to Colorado in October loosely planned. The rears have a lot more tread if I swap them.
A lot of tire age is how they are stored. I had a set of OEM Hankooks at 35k miles/5 years I had to switch on my Nissan truck as they were not safe in rain and weather checked like yours.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 1260 Views
Last post by cn90
- 579 Views
Last post by jreed
- 1656 Views
Last post by mrbrian200
- 740 Views
Last post by clarkerussell
- 248 Views
Last post by chitownV
