Gap in oil pan? 2007 XC70 Topic is solved
cmayo1
Year and Model: 2007 XC70
Has thanked: 51 times
Been thanked: 9 times
Post by cmayo1 »
I feel really stupid.
I recently dropped the oil pan on my Volvo. everything came out fine and the oil pan looked really good. I didn't end up buying the kit from FCP Euro and only bought the sealant. probably dumb but too late now.
I I resealed everything and while I was doing it I saw a little gap between the oil pan and the engine block. it's near the oil filter closest to the passenger side tire and has a bolt almost directly beneath it. I know it's a gap because the machine steel is much cleaner than the oil pan. I'm not currently with the car but I can get a picture .
I have no idea what this gap is. there's no way that I put this oil pan on wrong because I can't see any other way of putting it on. what am I missing? has anybody run into this problem before?
to explain it better, there's a piece of the engine block that is exposed and not touching the oil pan. it's not a gap between the sealant and The engine block. it is a protrusion that sticks out and leaks oil when the car is running. it's as if the oil pan is misaligned, but all of the bolts are in and secure. how else could it have gone on? what did I do wrong?
thanks in advance :)
2007 Volvo XC70
free time ≠ money
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Are you describing something like a half-moon gap in the block above the pan flange?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
You'll have to send a picture, I don't recall a gap when I did mine and I cannot think of anything you may have missed that would create a gap where the oil pan mates with the block.
2003 XC 70 (sold)
cmayo1
Post by cmayo1 »
BlackBart wrote: 04 Oct 2024, 15:50 Are you describing something like a half-moon gap in the block above the pan flange?
Yes, what your describing sounds right. I'm attaching a drawing of what I remember it being. The red is the pan, blue the gap, green the nut and yellow the filter. Your idea of what it looks like is probably better than mine lol
2007 Volvo XC70
free time ≠ money
Blacklab467
Show me on this picture where that gap you describe is.
2003 XC 70 (sold)
cmayo1
Post by cmayo1 »
Here it is:
2007 Volvo XC70
free time ≠ money
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Is this square the PCV return?
(EDIT: Is it critical to get the red material on the entirety of the square?)
Oil Pan.png (657.73 KiB) Viewed 324 times
cmayo1
Post by cmayo1 »
MoVolvos wrote: 04 Oct 2024, 16:54 .
Yes to both. Start your own thread if you have more questions :D
2007 Volvo XC70
free time ≠ money
MoVolvos
Post by MoVolvos »
cmayo1 wrote: 04 Oct 2024, 17:04
Will do! Do I need your or Blacklab467's permission to use the photo if I have further questions when I start another thread? Also, do I have permission to link to your thread if someone has the same question as yours?
MoVolvos
Post by MoVolvos »
Never mind I'll just check with the Moderators.
