I have a C30 2.5 Turbo T5 2012 with 140k Km
New PCV
New head gasket
New Turbo
The problem is:
At idle there is no smoke to talk about but under acceleration and when letting off it starts to smoke. Any thoughts or help would be appreciated..Thanks
Smoke - C30 2.5 T5 - 2012
- Has thanked: 2196 times
- Been thanked: 1850 times
Did you replace the valve stem seals?
CassioLince
- Year and Model: 2012 C30
So it smokes when you start the car? What color is the smoke and does it have a oil or sweet smell?
We have to be careful not to exclude work done as well. Some aftermarket part qualities are not that good, so using non-Volvo valve stem seals can be problematic. You may want to do a compression check to make sure you don't have low compression due to piston ring problems. This also helps for us to help diagnose from a distance. If you test the cylinder compressions 'dry' first, then add a tea spoon of oil to each cylinder, do the compressions change?
