Odometer 1992 940
billaddy
Year and Model: 1992 940
Post by billaddy »
Hello, I have a 1992 940 with a faulty odometer; speedo works so it is getting a signal from the sensor and the wiring to the cluster is fine. Problem is in the instrument cluster. Any good used ones out there or does anyone know if there is a repair facility that works on these older units? Thanks
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Many of these old odometers failed when a plastic gear aged out and broke. I have replaced a couple on 240 Volvos.
It appears odometergears.com https://www.odometergears.com/ does not have a fix for the 940.
Try these people
https://www.speedometercogs-gears.com/v ... r-set.html
The gear repair is fiddly but doable.
billaddy
Post by billaddy »
Thanks so much for your input. My cluster is a Yazaki not a VDO. I have had problems with many of these through the years and now they are like hen's teeth, hard to find. Be well.
Can you just replace cluster with a VDO? Or maybe the odometer/speedometer portion? Sorry if stupid question, all my experience is with 240s.
