1998-2000 V70 Tailgate Latch Autopsy 9485477 - Part number 8628197
Oro
Year and Model: V70 XC, XC70+S60 awd
Has thanked: 7 times
Been thanked: 37 times
Post by Oro »
Shappy wrote: 09 Sep 2024, 06:32 What an absolute nightmare! All this for an idiot light that is more annoying than helpful. Unless there is a way to totally disable this circuit (fuse? which one? wire snip? which one?, etc?) it looks like a bit of black tape at the left end of the cluster will be the way to go, and then check each time the tailgate is closed that it is actually closed. The same thoughts apply to the door latch except hat in that case there is the beeping noise to contend with. SHEESH!
Easy fix is:
- Remove broken pieces and spring. The hatch and lock will work normally without them. They are there to trigger the open sensor, nothing mission critical.
- Defeat the open light/sensor by pinning the microswitch shut.
All works fine now, no cost, but you lose the hatch warning function.
Remove broken bits.
Defeat the warning switch.
Has thanked: 1609 times
Been thanked: 4063 times
Cross posting the details on the plungers here in this thread
viewtopic.php?p=676535#p676535
Found my old latch of the T5 so will be able to work this problem with some free spare parts in hand!
See, it does pay to keep every part you ever touch.
(Ignoring $200 a month storage unit bill)
Has thanked: 2196 times
Been thanked: 1850 times
Also having a spreadsheet for storage locations helps! :D
