P80 C70 Hvac Drivers side only hot air, damper motor position, map of position counter, internal pictures
Is the C70 coupe a lot different than the s/v70 series?
- Has thanked: 2200 times
The dash is slightly different shaped to the V/S70 and V70XC. But I have not seen any major differences other than later ones with the music system.
CoupeC70
- Year and Model: C70 Coupe '01
- Has thanked: 10 times
- Been thanked: 2 times
@scot850
The C70 and V/S70 have many differences regarding the interior, but the dashboard is 100% the same except for the center console
P.S.
looks like the under-dash structure isn't 100% the same after all
we took the intact center section with the brackets from a V70 and swapped it with mine. All the brackets on mine were snapped off, and the air ducts were covered in cracks
P.S.
I do, too
The minor differences in the dash might mean big differences in threading out the driver side damper for temperature control.
Hopefully not. A really small torx bit driver is probably needed to access the screws.
CoupeC70
I think I accidentally made a mistake.
I opened the used damper to clean the grease off the track. I lifted the gear without making a mark first.
Now I don't know what position the gear was in. Is this problematic, or does it not matter if you do a calibration anyway?
Do some reading about this on the 99-00-01 models. I remember it is possible to get the HVAC control unit badly uncalibrated
CoupeC70
If I install the used damper motor, the calibration won't be right anyway. That's why I'm asking if it's a big deal that I didn't mark the large gear with the sliding contacts before cleaning the grease off the track. Or is the damper motor trash now?
Gemini told me it's no big deal. But what does Gemini know, haha...
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
From recently having made this mistake myself, it is possible to install the shaft + gear assembly rotated 90 degrees off from the correct position, and then the sensor position will be impossible to calibrate.
- 13 Replies
- 4260 Views
Last post by BEJinFbk
- 9 Replies
- 4113 Views
Last post by jvl
- 20 Replies
- 550 Views
Last post by cn90
- 986 Views
Last post by odaikorob
- 12 Replies
- 2104 Views
Last post by cbarbsnv70
