ECM 2900 - 2005 - V70R
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
600 KPa can be a relief valve.
I frankly don't remember seeing pressures above 600 KPa. Even if the engine was stopped and the ambient temp is scorching hot, the gas boils and vapor pressure is free to go as high as it can, the pressure was raising to like 580, but not higher. Also when I prime the pump a few times, it never goes higher than that.
Would be pity to replace a good working pump.
Can your Autel read the freeze frames for ECM-2900 and CEM-4A37?
RuudKoster
Year and Model: 2005 V70R
Post by RuudKoster »
I'm not sure if I have a freeze frame of the CEM 4A37, but I've attached a freeze frame of the ECM 2900.
RuudKoster
And one in english :lol:
RuudKoster
I have multiple freeze frames of the ECM 2900 fault. Every time it shows around 300 kPa fuel pressure..
When I read out live data at the event of the fault it always shows around 400 kPa.
Initially I thought that was the trigger of the fault, but I'm doubting if the pressure in the freeze frame would be the relative pressure and the live data the absolute pressure. But I'm unsure..
RuudKoster
Oh and the guy from the movieclip of the second post had 105 psi on a new pump which is over 700 kPa.
That is why I though my fuel pump must be on it's way out..
vtl
Post by vtl »
Okay. ECM and CEM are both not happy with the fuel pump. I would still inspect water intrusion into CEM and spray ECM contacts with electric contacts cleaner. If it's still the factory installed pump, it may have to go.
RuudKoster
Thanks for thinking with me! I think it's still the factory pump, but I'm not 100% sure..
I did inspect the ECM contacts and they looked perfectly clean.. No harm in spraying does contacts, so will do that!
What I just thought about the pressure from the new pump in the clip. That was relative pressure from the manometer.
I read my pressure from the Fuel Pressure Sensor which gives an absolute pressure. S difference between my pump and the new one is about 2,2 bar!
