Another task I am combining with my dash repair will be the key hack. I have a spare immobilizer ring. I plan to connect it to the harness with my programmed key and tuck it under the dash and then use unprogrammed keys.
I have seen a couple threads that say you must remove the chip from the unprogrammed keys or they will interfere with it? is that correct?
question on spare key hack
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Has thanked: 2196 times
- Been thanked: 1850 times
Nope. I have a remove starter fitted and the key is hidden under the dash to allow the car to start. It has been in the car for 14 years and no issues. I have not tried to see if it would work with a non-chipped key. Our 2 keys we use for the car are both OE chipped programmed keys.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
My 05 XC90 had the chip in the fob die. I was determined not to pay $150+ for a key. My chipped spare is under the dash and a local locksmith cut these…no interference issues.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Grantkat
just to be clear...after securing the key to the immobilizer, I can use keys that have the chip in them but not programmed... correct?
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Krons
Correct. My eBay ones supposedly had a chip in them…not sure/didn’t care as they only need to turn the tumblers in the steering column. Also I pushed the real chipped key/transponder pretty far forward so doubt another key would get a signal to it anyway.Grantkat wrote: 10 Jul 2026, 16:57 just to be clear...after securing the key to the immobilizer, I can use keys that have the chip in them but not programmed... correct?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Grantkat
ok Thats awesome thanks!!
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
So I have read about this issue before, but am completely ignorant on the particulars. Is there a general write up on what exactly is needed, and how to do it ? My '99 only has one key, and of course I'd like to have a spare.
What is the immobilizer, and where is it located ?
Is it a part I can get from the junkyard ?
Does it get spliced into the wiring ?
Is this a 850 issue as well ?
As I said, I'm completely and totally clueless on this.
1999 V70 GLT
1999 V70 GLT
- Been thanked: 4063 times
It is a trip to the dealer or someone with VIDA and an subscription to Volvo services for a North American 1999 model
- Sveedy
^ ? Grantkat's is a '99...
Now I'm even more confused.
1999 V70 GLT
1999 V70 GLT
Ah, if you want to go that route, you can skip the dealer. They will cut an unprogrammed key for you for about $50, then you put your one programmed key into the spare antenna ring, and use the unchipped key to start/run
You eventually will get a code for “ key in too long” but that’s non fatal
- 2143 Views
Last post by Richard_TD
- 2980 Views
Last post by Ludermilch
- 2479 Views
- 854 Views
Last post by JRL
- 3910 Views
Last post by Clemens
