Using sealant with cam seal?
Chili58
Year and Model: 2003 XC70
Has thanked: 3 times
Been thanked: 12 times
Post by Chili58 »
I've got major problems to get Volvo B5254T2 motor's front cam seal properly installed. It leaks.
Does anyone have experience in using additional sealant to get seal's outer surface not leak?
Been thanked: 504 times
Post by cn90 »
I posted the RTV trick in the DIY.
In the very same thread that you just posted a reply.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
I have covered the OD of the cam seals with a very thin coating the same red anaroebic sealant used for the upper to lower head seal. No problems from the 4 Volvo engines with this completed. I also did a thourogh cleaning of the PCV oil separator, added new hoses and clamps, and verified the drain down to the oil pan was clear.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Chili58
Post by Chili58 »
It has brand new entire breathing system - which works well.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Cam seal grinds a groove on camshaft. New seal has to be seated in at a slightly different depth.
Also not all seals are equal. I had to replace 3 out of 4 Corteco seals, because they were leaking. Volvo OE seals stopped the leak.
Chili58
Post by Chili58 »
In this 2,5 Turbo the seal does not touch cam, but only VVT and bliock+valvecover.
