I disagree for environments with high humidity and salt or chloride used on roads for snow and ice melting. Keeping the junction sealed from salt and corrosion is critical for maintaining electrical connections and grounding. The surface tension of dielectric grease isn't high enough to create the problems you are describing. There is more than enough pressure with a ground bolt the squish the dielectric grease out from the connection. The same applies to electrical plugs. I have significantly more problems with corrosion inside electrical connectors than I do with dielectric grease that will prevent future corrosion. The DEM (Differential Electronic Module) was non-functional in my 2004 V70R because a little salt water got splashed into the back seat area next to the door and ran down the harness into the unsealed connector and corroded the CAN high and CAN low plugs. I cleaned them with several applications of DeOxIt and then smeared in dielectric grease to prevent future problems. The problem was eliminated and prevented from recurrence.erikv11 wrote: 27 Aug 2026, 14:19Oops, bad practice, don't do this! TL/DR: Never use dielectric grease inside an electrical path. Use it outside or around the path.DavidE7 wrote: 27 Aug 2026, 11:29 ... I like to wire brush and put dielectric grease on the contact surfaces for the two ground bolts. ...
Dielectric grease is an insulator.
Its basic purpose is to keep things, like moisture or corrosive chemicals, out of an electrical connection. By putting it on the mating surfaces you effectively interrupt the path to ground.
Obviously your engine grounds are working well enough so presumably you're squishing out enough dielectric grease that there is still a sufficient conductive path through there, but why sabotage the grounds!
None of this applies if you live in Southern California, Nevada, Arizona or New Mexico without humidity and salt. You don't need to coat every metal fastener in anti-seize either.
The main reason I like P2 Volvos is the rust protection. These cars aren't perfect after 20+ years but they resist rust better than any other old car I see in Michigan.
