Thanks for the information Made in Japan,
I will find the tool to remove it.
Fuel Pump installation
woodrocanada
- Year and Model:
95 volvo 850 (not turbo)
hey yall,
a couple weeks ago my freshly purchased 850 stopped starting up. 3/4 tank. new battery. it was diagnosed with a broken fuel pump i decided i would try to replace it myself.
i bought a used fuel pump from ebay and followed the wonderful instructions found here to replace it. after the procedure (which i think went quite well, actually) i tried to start the car with no success. is there anything i might be missing? a special way to re-prime the system (i pulled the fuse to relieve the fuel pressure, but have since replaced it)? actually, even with the key in the ignition powering the car i cannot hear any noise coming from the pump. does this mean the one i bought doesnt work?
i apologize if i left out any details. any help/advice would be appreciated.
frustrated,
chris
hey yall,
frustrated,
chris
confused_al
- Year and Model: 1996 TLA wagon
https://www.matthewsvolvosite.com/forums ... hp?p=53579
https://www.matthewsvolvosite.com/forums ... &view=next
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
woodrocanada,
Noticed you are our newest member! Thanks for joining and let me be the first to welcome you to MVS. I hope you find answers to your issues here...we'll keep up with you until you're able to get this problem fixd, so hang in there!
-MIJ
-MIJ
woodrocanada
- Year and Model:
guys,
i will go out and remove and check the relay visually but i cant set up a 'jumper wire' (im not that technically inclined). i dont think it is the relay because the car was running fine right up until i drove it into the driveway and removed the pump fuse to relieve the fuel pressure (ie. it had power). the only problem was that i had to start it by hitting the tank with a mallet (this means it was the pump, right?).
MadeInJapan
Sound like you hit it on the head (pun intended).
- akitawagon
- Year and Model: 1997 855R
woodrocanada,
Having to hit the tank with a mallet to get started usually means that your fuel pump is going. Given the age of our cars, sometimes the fuel relay follows the pump or the relay goes out first.
The jumper wire for the fuel relay testing isn't too hard to do if you follow Ozark Lee's writeup in the links offered above. It's pretty much just a wire connecting two points to keep the fuel pump running so that you can make sure it works.
You still will need to verify if your relay is still good. Maybe you can find a friend with an 850 or someone (maybe on this forum) near you that can let you borrow their working one to try out.
You can also recheck the electrical connections for your fuel pump (the ones right near the pump). Make sure that the connectors are fully connected, some of the wires didn't get crimped when you placed the pump cover back on and then recheck to see if you can hear the pump turn on with the ignition key at Position 1.
Otherwise, you may have received a bad used pump.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
- 658 Views
Last post by erikv11
- 42 Replies
- 12432 Views
Last post by Maestrours
- 5239 Views
Last post by wizechatmgr
- 16955 Views
Last post by Richard99
- 2249 Views
Last post by precopster
