Horn don't honk!
AlanS
Year and Model:
Post by AlanS »
2001 S-40...horn does not honk if you press the lower portion of the pad. The upper right and left work, but not the bottom. Anyone have the 'how to remove and repair' pages of the manual? OR...could you just tell me how to do it? I have worked on my 850 and 740, so I have been inside before, just not sure of the details on this one.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is the VADIS instruction for getting into the steering wheel.
Disconnect the battery negative lead, having the radio code. Do no start work for at least 5 minutes after disconnection.
To remove the "Steering column panels" - remove 3 screws from the lower panel, lower the steering column to its lowest point and remove the upper panel.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
tkuper
Year and Model:
Post by tkuper »
When I disconnet the neg battery cable, will I have to go to the dealer to erase codes?
billofdurham
tkuper, welcome to Matthew's Volvo Site.
Which codes have been set? I can't find any associated with the horn not working.
Bill.
Previously:
tkuper
Year and Model:
Post by tkuper »
I don't show a code yet, but the last time I lost power, the airbag warning came on and I had to pay $60 to have it reset.
Thanks,
tkuper
billofdurham
I don't know how that happened but the correct procedure for disconnecting the negative cable is:
Turn ignition key to position 0 and disconnect the cable.
To reconnect the negative cable:
Turn ignition key to position 11 and reconnect the cable.
The reconnect part often catches people out.
Bill.
Previously:
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I split tkuper's last post because it was about an XC70. It is in the '01 and newer forum if someone looks for it.
