850 turbo turnsignal stalk broken
850turbocarl
Year and Model:
Post by 850turbocarl »
Hi Gang, My left turnsignal stalk broke on My 94 850 turbo and is hanging by the wires. Is it a tough job to replace it? It looks like the switch is not hard to replace but one has to remove the steering wheel and the airbag. Also it doesn't show what fasteners are recessed in the housing. Thanks,
859 turbo Carl
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
All you need to remove to get to it is the collar around the steering column.
dcovey
Year and Model: 1998 S70 GLT5
Post by dcovey »
Yup, pop the top cover off the steering column, remove the bottom cover, it will have 2 T25 Torx screws and a T15 Torx screw.
Now you remove the two T25 screws that hold the turn signal switch to the steering column, and unplug the connector.
Reverse process.
Now drive 45 miles per hour in the left lane of the freeway with your signal on to simulate eligibility for the senior discount at IHOP.
1998 S70 GLT5
16T, White Injectors, .040 Overbore, Masterlube pre-oiler, Teflon intake manifold spacer, VMS Performance ECU, VMS rods, ARP Studs, MSD Ignition, Reverse IC piping, completely new from the firewall forward.
