I understand the CMP sensor is the camshaft position sensor. Here's a picture of it: http://www.fcpgroton.com/images/9146108.jpg
-Paul
CAR SHUT OFF!
Paul93-850
- Year and Model:
93 volvo 850 glt
someday I'll get a 7 seater wagon
93 volvo 850 glt
greg94
I just bought a '94 850 3 days ago (180k) & clean- runs great until this afternoon.
It started, died and wouldn't fire until the 5th try over the next 10 min.
then it started and run perfect for the trip home (20 min)
lxt
Tina, is it the same one that you said has a broken valve elsewhere on these boards? It's not considered "fine since" is it?tina wrote:My '94 850 shut down in traffic last year, then got it started but over the next day ran/shut off. It was the fuel pump - replaced and fine since!
Anyway, I'm glad you found the replacement so quickly. For some reason I always thought you're that Tina who won the 1m on Survivor!
tina
- Year and Model: 1998 S70, 2001 S40
- Been thanked: 2 times
Well regarding that issue it was fine! I meant no more stalling problems.
As for the bent valve on my 850, it was likely a problem with the timing belt I had replaced the day before - or the tensioner that I did not have replaced. I'm going to have a valve job done and sell the car, it's still very pretty and has lots of new parts (courtesy of my pocketbook)!
I found a place that can probably do tha valve job cheaper - it's 2 hours away and won't be very fast that's why I needed to replace the car as it's my only transportation. I think the 850 still has lots of life left in it.
Alfredo
It happened to me twice since I get the car in 1998 and the problem was the fuel pump, in fact I changed both the fuel pump and the relay and the problem was fixed, seems that the fuel pump for 850/1994 last two years more or less.
Alfred
Caracas/Venezuela
Alfred
Caracas/Venezuela
seamansteph
- Year and Model:
Same issue with me we did everything that seemed logical & still it stalled he replaced my dist. cap & rotor it was fried ,never stalled again!
- 2176 Views
Last post by BEJinFbk
- 2093 Views
Last post by RLBOHNER38
- 12 Replies
- 2832 Views
Last post by erikv11
- 680 Views
Last post by DGM
- 19 Replies
- 5302 Views
Last post by Eliotlm
