All the clips for the loom onto the fan cowl were destroyed by some ham-fisted garage monkey. I manages to buy 'fir tree cable ties' last week and it's now all tidied and back to factory stage zeroBlacklab467 wrote: 08 Dec 2023, 08:03 I was going to comment on the wiring routing around the top of the radiator on the previous picture but I see you've gotten it sorted out in the subsequent photo. Beautiful car and engine bay!
Identify this part - fuel system?
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Would you mind taking a couple detailed photos of how and where the wiring attaches to the shroud? Mine's incorrect and I can't tell for sure exactly how its supposed to go, also I have some clips on the headlight wiring loom that are supposed to affix the wiring to flat sheet metal and Im not sure where they are supposed to attach, thanks.
2003 XC 70 (sold)
- P80GLT
Not sure my pictures will be much help
This is an eBay image to show the position of the holes
All red arrows are where the cooling fan harness is clipped into.
All yellow arrows are for the alternator A/C harness (I presume that's where the wires go!!!) I'm not sure if there should be a fir tree clip where the blue arrow is, I feel it would throw the line of the cable out a bit so I just used a plain cable tie for that hole
Headlamp connections clip onto the top plastic of the headlamp backing
- Blacklab467
Excellent, thank you!
2003 XC 70 (sold)
weitau
- Year and Model: 2004 V70
- Has thanked: 7 times
- Been thanked: 2 times
Thanks for the PN! I did find my part from the salvage yard for less than $20.P80GLT wrote: 07 Dec 2023, 10:17 It's the switch for the brake vacuum pump part number 31400692 and yes it's in the correct location
2004 V70 2.4L
Don’t forget to zip tie your new / old part!
weitau
To be honest, I haven't tested the pump yet because the brakes seem to be fine, and another emergency came up. After 3000 miles, there was only a drop of oil on the dipstick
2004 V70 2.4L
If you still had oil on the dipstick, even just the tip, it’s fine. Keep it between the hash marks but no worries about getting a bit low in the crankcase, no damage done.
Im downstate on Long Island mostly , with biweekly Trips up to Albany
weitau
Thanks! that's reassuring. Another thing, which may not be so important, is that it takes about 10 minutes of driving before the engine temp gauge gets to half way to normal operating. That's today at 33 degrees. Maybe the thermostat is stuck open? the quicker the engine reaches normal operating temps, the better.abscate wrote: 18 Dec 2023, 04:42 If you still had oil on the dipstick, even just the tip, it’s fine. Keep it between the hash marks but no worries about getting a bit low in the crankcase, no damage done.
2004 V70 2.4L
- 1252 Views
Last post by 93Regina
- 2362 Views
Last post by dconklin
- 726 Views
Last post by etf48
- 719 Views
Last post by FLXC90
- 2169 Views
Last post by Sommerfeldt
