Um, I don't know...I'm confused, Al.....LOL
I think that as long as you don't over-tighten the lug bolts, you won't have any trouble getting them off so there is no need for any lubricant or anti-seize. I've never had any issue getting mine off, ever.
Lug Wrench Causality
- Has thanked: 17 times
- Been thanked: 35 times
Using air wrenches to tighten lug nuts is a dangerous practice and should be stopped. After buying tires or getting them changed, I assume they were put on by air wrenches and are way too tight, so I get out the 4 way wrench and a pipe extension, and loosen them. If I had to do this out on the road with just a wrench I would never get them loose. The standard Volvo wrench was warped out of shape long ago. I have never found a lug nut loosen up after tightening them well with a 4 way.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
I use anti-seize on my lug bolts. I don't think there's much choice as around here the amount of salt they use on the roads makes them seize faster than you can keep up with.
I am familiar with the principal that lubricating threads reduces the torque requirement for a given holding power.
Nevertheless, I am sticking to the highly scientifically accurate torque setting of "good and tight". I know I'm not doing them as tight as the guys with the impact wrench at the local shop, but I'm doing them as tight as I can get them with my 4-way wrench. Probably around 80 ft-lbs.
- Been thanked: 504 times
Resurrecting an old thread.confused_al wrote:Its funny, I just had a lengthy debate with my fellow engineer friend on this topic.
My point is the torque we tighten lug bolts should be static state, not dynamic state. Therefore any thing that only reduces dynamic resistance (when you turning the bolt), such as grease or any other forms, will not change the torque at final resting state (after bolt stopped turning).
Do you guys think I won that debate?
Yes Al, you won the debate.
- Yes use antiseize, a small dab on the threads is sufficient,
- Get a breaker bar and 19-mm impact socket as spare. I nearly broke my factory wrench because as Lee said: the monkeys at Firestone over-torqued my lugs!
- And yes use Torque Wrench.
For those who fear the use of antiseize: in order the damage the hub and break the lugs, the torque has be very very excessive such as 250-300 lb-ft.
So a little bit below and above the spec is fine. As Lee says 81 lb-ft is the spec, but if you go to 75 or 85 lb-ft, it is NOT the end of the world. There is always some room for errors.
I have been using antiseize and use factory torque of 80-90 lb-ft in many many many cars: zero problems in 25 years of wrenching. Zip, nada and nada problemo!
db130
- Year and Model: 2002 V70 T5
as suggested before earlier on this thread, i too would suggest purchasing a 1/2" breaker bar for additional leverage. one that is 18" in length could be had for as low as $11.99 from your local Autozone, and a 24" one from Gearwrench/SK tools could be had in the $30 range.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
VolvoTurbo850
- Year and Model: 1994 850 (T5)
I have the ultimate solution for you Volvo wrenchheads like me
I purchased this 3/4 with an adapter for my sockets. I use it for everything when I cant get my air tools or electrics to the car. The unit is heavyduty and about 15 inches long, but worth its weight for weekend mechanics.
You can also put a lead pipe on the end to extend your leverage. I have used it to remove axle axle nuts to lug nuts as well as some suspension work.
Unlike lots of these johnson bars or lever bars, it will not crack or break at the end.
I know it goes on sale for about 30 bucks in Canada so I am sure you can purchase it cheaper in the USA.
I swear by it for removing bolts. I use a torque gun to put on my lugs by the way!
www.princessauto.com/workshop/hand-tools/driving-tools/ratchets/2920099-3/4-dr-quick-release-ratchet
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
JDS60R
- Been thanked: 3 times
Some material you may be interested in
http://www.arp-bolts.com/pages/technica ... tion.shtml
http://books.google.com/books?id=5a8937 ... &q&f=false
Retired
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I have never torqued mine to spec, I just use a 19mm socket and breaker bar and torque to feel. Have never had a problem with loose bolts, warped rotors or trouble loosening them. It can be done.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
I set up my torque wrench to 81 and take it with me to all the tire places I go. I ask the sales manager to be sure they use torque wrench on my lugs! one time I tipped a guy $10 when he went ahead and did it on his own. i too have broken tools trying to get lug nuts off!
99 V70XC 158K
95 850glt 188K
95 850glt 188K
- 25 Replies
- 4235 Views
Last post by TWC
- 590 Views
Last post by jreed
- 1978 Views
Last post by rmmagow
- 16 Replies
- 3253 Views
Last post by hammertime
- 5221 Views
Last post by MarcM
