just did a simple mod and WOW!
trophytaker308
- Year and Model: 1995 850t turbo
well if i did it wrong it would of not line back up properly like it showed me in the vid,right???
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
What the crap?
2-3 turns at MOST.
You're going to blow up your engine. 10+ PSI at 2000 RPM will bend rods.
2-3 turns at MOST.
'98 S70 T5
2016 Chevy Cruze Premier
s70glt novice[Will]
- Year and Model: s70 glt 98
what you did, im assuming, was turn it by hand and pull it out to fit over the wastegate. its not actually set at that psi, but is being forced to.
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
s70glt novice[Will]
the best thing to do is to get the wastegate tool, and adjust it with that. Adjust to stock settings, drive it for a bit and see if you like it. if not, you can do 1-2 turns MAX.
'98 s70 GLT-127k
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Bad idea doing it blindly without checking wastegate pressure and without a boost gauge.
The amount of boost isn't the issue, it's the fact that it's coming on so early. That's what bends rods.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
trophytaker308
jblackburn wrote:What the crap?
2-3 turns at MOST.
wow i was at 4 or more...lol grang ,should i not be in the half way mark in my white line,is that 2 much....did lucky have a different motor i wonder???
trophytaker308
no i did not pull it back to fit,i turned it back so it would fit like he said.trophytaker308 wrote:well if i did it wrong it would of not line back up properly like it showed me in the vid,right???
s70glt novice[Will]
No, i think your problem of not building boost was coming from something else... investigate further. Have you done your vacuum lines?
Did you use the ipd wastegate tool? or twist it and pull it on?trophytaker308 wrote:no i did not pull it back to fit,i turned it back so it would fit like he said.trophytaker308 wrote:well if i did it wrong it would of not line back up properly like it showed me in the vid,right???
'98 s70 GLT-127k
trophytaker308
all my vacumes ar fine,no leaks,and yes i used a tool from a friend at fast trax race shop.
s70glt novice[Will]
okay... that makes more sense... what psi on the tool did you set it too? I believe stock is around 3.5? That may be for just the newer s70s
'98 s70 GLT-127k
