2000 S70 No Start, feel like I've tried everything...
This topic is in the MVS Volvo Repair Database » 2000 S70 No Start
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Examine all the numbers on the thing. go to car-parts.com and look around. If you can find a junk yard close to you go there w/old ECU to match the numbers. Ebay the same, look to match numbers. I am thinking the ECU from Volvo would really set you back a lot. A used exact match should be OK.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You can't change over a ECU with another used unit on these models (post '99) without changing other matched components.
However you can swap the old ECU with a new one at the dealer without those other components (and at great cost).
We had a discussion about this about 2 months ago here and I can't recall exactly what the other parts were but I recall going over to Volvospeed and many of the members chimed in about it. One of the things I recall was ETM and another was the ignition section (transponder in keys and ignition section that accepts signal)
Seems your car knows you've swapped the ECU and the battery cable reset is fooling it but only until the next start cycle.
Did you fiddle with any of the items above before getting the no-start?
tjmonjay
Year and Model: S70 2000
Post by tjmonjay »
Well i didn't swap the ECU i swapped the TPS. The whole no start issue just randomly started while i was on break one day. I am thinking it is something to do with the key/ignition switch the more i read on it.
nickh
Year and Model: 1995 850 T5
Post by nickh »
I was having the same symptoms with the missing ets, cel , and oil lights. may have found the problem. there is a common ground wire that is held in place by the passenger side hood latch. took it off , cleaned it up , reconnected and she started first try. like nothing was ever wrong. Only because I removed the entire box surrounding the computers did I just happen to see this corroded wire, although you do not have to remove the cover to access it. Hope this helps...
1995 850 T5 190k stage 3 +
1997 855 T5 185k stock
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Thanks Nick. These fixes are the the best to know about, the kind you'd never think of in the normal troubleshooting process.
Also -> Amazon link
marcusheard
Year and Model: S70 turbo, 1998
Post by marcusheard »
What does this common ground look like? Did this fix the guys problem who started this post? I have a similiar issue - no spark and no uel unless I jump the main relay.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Antennae ring?
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
byeboy
Year and Model: 850R, 1997
Post by byeboy »
Reminds me of a quirky problem (one of many) with my 245 wagon, where the windshield wipers started coming on while the headlights were on...with the great help of members on the brick forum, it turned out being a ground wire connection (just a wire screwed to the floor) under the carpet, padding, etc. in front of the shifter (it was a manual trans)...I would have never thought to look there...but it was one of three spots on that car that were suggested . One was the taillight, the next was a body ground behind the battery (had to remove to access), and then the hidden screw under the carpet. I each case I removed the screw, hit the spot with my flap disc (just a touch), cleaned the wire connector (carefully inspecting it, then smearing some dielectric grease on the bare spot , the connector, then using a fresh washer and screw.
Grounds can cause mysterious problems!
ONV70XC
Year and Model: 1999 V70 XC
Post by ONV70XC »
Hi I have em all spare: ECU, ETM from 2001 V70. If you have VIDA installed onto your laptop you can reprogram it to your VIN.
Drop me a note if you're interested and we'll talk about shipping etc...
ONV70XC
Post by ONV70XC »
