Fairly simple dash rattle fix
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
cn90 wrote:The previous owner folded some kind cardboard material and wedge it between the glass and the dash at the very edge where they meet each other, it is not a very elegant repair but it worked. I trimmed off the excess so it is barely visible. I just learn not to look at his "ghetto" repair LOL.
I don't have a photo of my "setup" yet, but the idea is like the diagram below, get something and wedge it at that spot:
Yep, that's what I did. Shut it up for the most part.
Blech, the S70 just looks wrong with a tan interior.
'98 S70 T5
2016 Chevy Cruze Premier
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
yep, this is probably the oldest quick-fix trick in the book for this problem in an 850/x70, anyone who wants to just keep the car on the road then go for it, it is very tried and true.
zangado
Year and Model: 2002 S60 AWD
Post by zangado »
How about a squeeky glove box noise? It seems to be the actual door lock that doesn't seem to be fully secured when it is shut in my S60. Is there a adjustment that can make the door shut more tight?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
zangado wrote:How about a squeeky glove box noise? It seems to be the actual door lock that doesn't seem to be fully secured when it is shut in my S60. Is there a adjustment that can make the door shut more tight?
I put a couple felt stickers on my glove box. Like the ones for furniture feet.
Also -> Amazon link
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
Went to take a photo and discovered that the dash covered up my fancy little brackets but the car is so much quieter-now I have to solve the tailgate banging and clunking, or turn the stereo up
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I am thinking another "ghetto" fix. Get some vacuum tubing (the same as windshield washer rubber tubing). Measure the length of the windshield from R to L.
Then tuck this vacuum tubing along the edge (where the windshield glass meets the dash) for its entire length from R to L.
The black color of the vacuum tubing should blend in nicely with the dash color.
skloon
Post by skloon »
The tube may work for some but my dash was so loose I could pull it back and forth about 1cm my other 850 had the cd changer in the glovebox and has a bracket behind the glovebox and a couple of hefty torx fasteners holding it in, I think in an accident the CD changer bracket may be one of the only things left undamaged, it is one serious chunk of kit to hold in a simple item
zangado
Post by zangado »
Not a bad idea,im going to look into that...thanks.
