Fairly simple dash rattle fix
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
Looked at all the suggestions and tried this, I cut a couple of chunks of 1/8 aluminum about 3cm square, bent it gently in the middle and fitted it under the front of the dash under the window defrost grills on the sides, there is a screw that holds the dash pad there and I replaced it with a longer one that I screwed into the chunk of aluminum. I then drilled a couple of holes through the aluminum into the door frame and screwed that down tight, it sure stopped the rattles but I will wait to see how it lasts
- Has thanked: 2861 times
- Been thanked: 1332 times
Nice thinking. Ill be following this. I keep balking at Amazon.com's $15 no-squeak tape.
castconcrete
- Year and Model: 1996
Do you have photos of process or finished project that you would share?
Thanks.
Thanks.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The dash rattle was muffled because of every other suspension noise, now after new suspension, there is a chorus that changes with road conditions, D, N, stop, take-off, you name it.
If you are from Vienna, record it and sell it under an artist's name who is dead as an experimental music. No Strauss, he was just Waltz.
I can't weight for this fix.
- Been thanked: 504 times
The LONG way:
http://www.volvo-forums.com/t11882-dash ... repair.htm
The QUICK Fix:
http://volvoforums.com/forum/volvo-850- ... nts-59650/
The Long way is like listening to Beethoven's 5th Symphony, a long majestic masterpiece.
The Quick Fix is like a Minuet by JS Bach.
I voted for JS Bach!
The QUICK Fix:
- Has thanked: 311 times
- Been thanked: 817 times
Then there's this one, still requires the effort of removing the dash but better addresses the problem of crumbling plastic.
http://volvospeed.com/vs_forum/topic/14 ... ir-on-850/
xHeart
Why bracket, and not just fastening dash to the metal body, screw or rivet?cn90 wrote:
The QUICK Fix:
The previous owner folded some kind cardboard material and wedge it between the glass and the dash at the very edge where they meet each other, it is not a very elegant repair but it worked. I trimmed off the excess so it is barely visible. I just learn not to look at his "ghetto" repair LOL.
I don't have a photo of my "setup" yet, but the idea is like the diagram below, get something and wedge it at that spot:
- 18 Replies
- 6582 Views
Last post by BEJinFbk
- 21 Replies
- 2233 Views
Last post by MrAl
- 879 Views
- 14 Replies
- 3759 Views
Last post by alfatango1
- 1091 Views
Last post by packetfire
