1999 V70 T5 Ignition Switch replacement with Pictures 9447804
This topic is in the MVS Volvo Repair Database » Ignition Switch Repair: Electrical Fix - 1999 V70
RayCis
Year and Model: V70 1999
Post by RayCis »
Thanks for this excellent explanation, my electrical problems were more or less identical, when starting, the horn, window motors, heating/airco fan, radio, wipers, all didn't work. Two times, after driving 2-5 minutes, everything worked, the 3rd time driving, problem persisted. So, it looked similar to issues, linked with ignition switch, but in this case it came down to a faulty relay, hidden somewhere below a fuse box, when that was done, all was fine again
Has thanked: 1611 times
Been thanked: 4074 times
Adding to thread
Not all pins on the electrical connector are populated - on my car, this is what they look like
YMMV
1999 V70 Ignition switch connector view
mynoralvarez
Year and Model: 850 GLT 1995
Post by mynoralvarez »
RayCis wrote:Thanks for this excellent explanation, my electrical problems were more or less identical, when starting, the horn, window motors, heating/airco fan, radio, wipers, all didn't work. Two times, after driving 2-5 minutes, everything worked, the 3rd time driving, problem persisted. So, it looked similar to issues, linked with ignition switch, but in this case it came down to a faulty relay, hidden somewhere below a fuse box, when that was done, all was fine again
To be totally honest I fear those buggers! I think they are hard to replace because of they are hard to reach.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Entered into Volvo Repair Database. Great writeup, abscate.
Also -> Amazon link
bob850
Year and Model: 1996 850 Turbo wagon
Post by bob850 »
Which relay is that?
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
nzvlnr
Year and Model: 1999 s70t5
Post by nzvlnr »
Could you detail your symptoms? My volvo is acting really weird,,...dash is like a xmas tree and I already tried the abs module...
nzvlnr
Post by nzvlnr »
Could this be the culprit
The attachment DSCN0760.JPG is no longer available
....this is what is happening..
.? I have a new one being shipped here on Monday...
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
nzvlnr
Post by nzvlnr »
I received my new switch yesterday, installed the new hardware. I drove the car to work this morning and it is running much better than it was,......but....I traveled about 25 miles and SAME ISSUE..... :roll: .....I lost my instrument panel, speedometer, tachometer and the ABS and Brake lamp lit up......I read that someone had similar issues and it turned out to be a relay?
nzvlnr
Post by nzvlnr »
Can you provide some detail on this? WHat/where was the relay. Did you lose your instrument panel, speedo and tachometer? My abs and brake light lit up as well...
