1994 Volvo 850 ( Stall then no start )
mmd94
Year and Model: 1994 Volvo 850 Base
Post by mmd94 »
Im still working on the issue, however someone brought up that if the cam jumped a notch on the belt this could stop the car, Is this true? would the car still at least try to start, or not. And i know the damage possible if the cam jumped, Im not sure if it did or didnt, but I need to check.
mmd94
Post by mmd94 »
although im not 100% sure i have broken valves, or damage due to cam timing, im looking for information to help me replace these if need be. such as everything ill need, time it takes, and everything i should replace.
Has thanked: 1611 times
Been thanked: 4074 times
What are the results of diagnosing spark at the plugs?
You have to be systematic at troubleshooting ..ignition, fuel, engine mechanical....in that order.
mmd94
Post by mmd94 »
Spark plugs and wires check out. However, should i be getting battery voltage to the main lead from ignition coil?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
A car needs 5 things to start; air, fuel, compression, timing, and spark.
