Volvo S60 Code p1026 Installed New Sacer sensor, still probl
Ok, Thanks Mike. I Got my voltage of 1.39v. Weird though, terminals 1& 3 Measured about 7.6v, but 2 &4 on pot1 side was 1.39v. So I matched that with the Sacer. It ran great for a few days of driving and starting several times each day. Then it acted up again last night setting code P1026 again and wouldn't clear, hard fault. Started it up this morning and perfect again. Must be in the throttle body, not the sensors, just like you said. What options do I have to get this thing fixed? Any wiring harness problems on these by chance? Again Thank You Mike, you have been a blessing!
precopster
- Year and Model: Lots
- Been thanked: 128 times
Grab another 8644345 or 8644344 from eBay or a parts dismantler and contact MVS user doublebug if it needs programming. (though you'll need Vida/Dice if you want to do this)
It's likely it will suit without programming however it depends on your ECM sw version.
There is a rebuilt part number available through dealers which is 36050564
If you want to spring for a new one the new part number is 3600 1821.
Tasca parts have great pricing on the last 2 numbers
precopster
More than likely for the first number (36050564) and DEFINITELY on the second part number (36001821)jb6992 wrote:If I use the new or rebuilt one Tasca Parts I will definitely have to have it programmed Right?
HOWEVER doublebug can handle it if you have a Dice reader.(borrow is good)
- 3966 Views
Last post by bmdubya1198
- 1291 Views
- 1049 Views
Last post by tardcart
- 516 Views
Last post by russloyd
- 2322 Views
