2005 V70NAM56 cabin filter change DIY 30630752 30630754
This topic is in the MVS Volvo Repair Database » P2 Cabin Filter Replacement
Has thanked: 1609 times
Been thanked: 4063 times
Climate system on the P2 sure is dreamy both in summer and winter. I understand the Evaps got a lot better too, here's hoping to at least 5 more years of life.
beigg
Year and Model: 850 97
Post by beigg »
I like the use of thicker ones as they tend to separate outside smells well, like the car in front that is not burning fuel efficiently or has an oil dependency diet...
ugh smh 850 Turbo fridge
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
P2 don't have problems with the evaporators. Only issues with the a/c system is the clutch pulley bearing @100k miles - $15 diy, and the cabin temp sensor - $50 @2 min. job
I would consider replacing the bottom air filter cover, the one kept with 4 screws. It tends to leak water under the carpet.
Where do you guys get the thick filter?
I'm sure both IPD and FCP carry them.
V70r carbon
Year and Model: 2005 v70r
Post by V70r carbon »
The "thickness" of the filter has nothing to do with the airflow through a new cabin filter, it has to do with the filter's MERV rating...
Minimum Efficiency Reporting Value. The "thin" filter is actually more efficient and will take longer to clog up than the thick one because of the number of folds the thin filter has. If you take apart and stretch out each filter you'd see that the thin one will be quite a bit longer than the thick filter which means it has more surface area for the air to pass through without restriction.
