2005 V70NAM56 cabin filter change DIY 30630752 30630754
P2 Cabin Filter Replacement
- Has thanked: 1611 times
- Been thanked: 4072 times
Climate system on the P2 sure is dreamy both in summer and winter. I understand the Evaps got a lot better too, here's hoping to at least 5 more years of life.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
P2 don't have problems with the evaporators. Only issues with the a/c system is the clutch pulley bearing @100k miles - $15 diy, and the cabin temp sensor - $50 @2 min. job
I would consider replacing the bottom air filter cover, the one kept with 4 screws. It tends to leak water under the carpet.
Where do you guys get the thick filter?
I'm sure both IPD and FCP carry them.
V70r carbon
- Year and Model: 2005 v70r
The "thickness" of the filter has nothing to do with the airflow through a new cabin filter, it has to do with the filter's MERV rating...
Minimum Efficiency Reporting Value. The "thin" filter is actually more efficient and will take longer to clog up than the thick one because of the number of folds the thin filter has. If you take apart and stretch out each filter you'd see that the thin one will be quite a bit longer than the thick filter which means it has more surface area for the air to pass through without restriction.
