850 rear flexi-brake hoses. How to replace?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I would advise the rear end in the air, with full suspension drop. That's the only way I have done it.
Has thanked: 2199 times
Been thanked: 1851 times
I have the whole car in the air just now, but will re-position the rear jack stands to allow the suspension to drop and re-assess. Thanks for the heads-up!
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Please take some pics of the hoses, I am curious how they hold up, I can barely see mine.
If you replace them a DIY would be great, I haven't seen a fully detailed one.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
m96ag
Year and Model: 2000 V70XC
Post by m96ag »
scot850 wrote:I have so far had good success with my trusty (expensive) Snap-on brake pipe wrench (can never remember what you guys on this side of the Atlantic call it). I'm sure it will let me down at some point but so far so good!
Flare nut wrench?
2000 V70XC 160,000mi.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
erikv11 wrote:I would advise the rear end in the air, with full suspension drop. That's the only way I have done it.
+1
Here is the link for more details.
http://www.volvoforums.org.uk/showthrea ... 9f&t=68111
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Sure, dropping the suspension is the way to go, but...
No need to drop the suspension as long as you do exactly what I said above, remove the whole thing as a unit, from the Y-connector to the RR caliper as a single entity.
Thanks for all the input. I will take pictures and do a how-to if I decide to tackle this. I really need to figure out the oil pan issue first and get the car on the road to see if there are any other nasty surprises. If time allows I will then get back to the brakes.
confused_al
cn90 wrote:Sure, dropping the suspension is the way to go, but...
Hey CN, long time no “see”!
Allow me to clarify what I meant by “dropping the delta link”…
If the jacks are placed at the rear side of the frame securely rather than under the delta link, the delta link will drop down about a couple of inches by its own weight.
98 MB ML320
06 V70
95 850 GLT(RIP)
Post by erikv11 »
Yeah, "full suspension drop" and "dropping the suspension" are completely different things.
"Dropping the suspension" is definitely *not* the way to go out of the gate, that is far more work than may be necessary.
For someone with Neil's experience, this is just another standard repair, he can take the usual approach: start with heat and smarts and the right tools to just remove the fastener (fitting), if that doesn't work then back up to a more elaborate approach like first removing the whole line from the car. As a very, very last resort one could drop the suspension, I guess.
That will be my approach, but I have bigger fish to fry first....!
Thanks,
