Clutches pressure plates and flywheels
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
tryingbe wrote: Neither? I'd suggest stock.
+1
beigg
Year and Model: 850 97
Post by beigg »
Last option might be all stock, but that wouldn't be the fastest/cheapest route in my case. Piecing everything together it's about a $100 difference and pending whom I go thru for it all, it can become long lead times for select items. If I go with aftermarket and mostly non OEM standards, it shortens the lead times 1/2 or greater.
ugh smh 850 Turbo fridge
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
beigg wrote:Last option might be all stock, but that wouldn't be the fastest/cheapest route in my case. Piecing everything together it's about a $100 difference and pending whom I go thru for it all, it can become long lead times for select items. If I go with aftermarket and mostly non OEM standards, it shortens the lead times 1/2 or greater.
http://forums.turbobricks.com/showthrea ... 0+flywheel
85 GLH, 367 whp
00 Insight, 72 mpg
beigg
Post by beigg »
Thank you for the link.
hopefully they're motivated to sell.
tryingbe
Has thanked: 1 time
Post by tryingbe »
$500 minus the hydraulics for everything pulled and you still want them to be motivated?
85 GLH, 367 whp
00 Insight, 72 mpg
beigg
Post by beigg »
tryingbe wrote:$500 minus the hydraulics for everything pulled and you still want them to be motivated?
Motivated can relate to many aspects to a for sale ad.
1. Not being lazy in providing information
2. Timely responses
3. Price negotiations based on the item(s) conditions
4.
5.
6.
7.
As I should not need to give the examples, it may provide value to those buying/selling... That's if the need for motivation is seeked.
greg850r
Year and Model: a long list
Has thanked: 5 times
Post by greg850r »
tryingbe wrote:
greg850r wrote:I don't see that part listed anywhere Dealer only? Anyone replaced one?
Zero internal manual transmission parts available anywhere. Many people tried, zero succeed finding anything.
Pivot arm and boot you might be able to get from the dealer. Call and find out.
My pivot arm looks ok, turns out the throwout bearing was starting to punch through the pressure plate springs.
I did find one here though.
http://www.tascaparts.com/volvo/850/914 ... lease-fork
beigg wrote: So which one is the one you are suggesting for the 1997 850?
This is what I'm leaning towards.
https://www.fcpeuro.com/products/volvo- ... -k70110-01
Have not seen flywheel surface yet but I'm hoping to re-use it.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
tryingbe
Has thanked: 1 time
Post by tryingbe »
That's an n/a clutch.
http://www.tascaparts.com/oe-volvo/272218
Then, get the throw out bearing you need.
85 GLH, 367 whp
00 Insight, 72 mpg
greg850r
Post by greg850r »
Have not seen flywheel surface yet but I'm hoping to re-use it.[/quote]
Then, get the throw out bearing you need.[/quote]
The GLT sedan I'm working on is not a turbo and the FCP is a Sachs that comes with the throw out bearing and ships free
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
polskamafia mjl
greg850r wrote:
The GLT sedan I'm working on is not a turbo and the FCP is a Sachs that comes with the throw out bearing and shipps free
Ok...But OP is working with a turbo. So the kit you linked to wouldn't work.
