Serpentine belt does not fit Topic is solved
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
A while back (Jan 2016) one of the vendors shipped me a Contitech belt that was labeled on the outer package as a 1743 but the belt inside was labeled 1741. It wouldn't fit on. I asked the vendor about it and they told me that they had received a batch of belts with the wrong size but in the right package.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have a good video that shows how to route it both ways.
- rspi
Contact rspi..
Serpentine belt routing on the Volvo 850, S70, V7…:
That's the thing - I've done belts before (mostly on my Land Rover) and its always been pretty straightforward. I look at all of the pulleys and the belt is sitting on all of them properly and the tensioner is pulled back and locked with a pin (I tried going past that point and it moves only a little bit, not enough to make a huge difference). I am going to the the wheel off and access the crank to make sure its sitting on it properly. Btw I've tried going onto the idler pulley last - same thing, about an inch too short.
- rspi
Contact rspi..
Did you watch the video?
How much the idler changes the belt path is a function of how big a sector it subtends, but small changes are important! Get every last bit of tension on that idler.
- Has thanked: 311 times
- Been thanked: 817 times
This is an informative post. Did you eyeball that the belt itself says 1743 on it?jreed wrote:A while back (Jan 2016) one of the vendors shipped me a Contitech belt that was labeled on the outer package as a 1743 but the belt inside was labeled 1741. It wouldn't fit on. I asked the vendor about it and they told me that they had received a batch of belts with the wrong size but in the right package.
How many MVSers does it take to change a serp belt ...
- 1274 Views
Last post by dm635
- 20 Replies
- 17359 Views
Last post by Hurtfeelings
- 21 Replies
- 5288 Views
Last post by viper69
- 22 Replies
- 35766 Views
Last post by erikv11
- 62 Replies
- 17751 Views
Last post by Shanestrait
