Belt tensioner torx bit
Has thanked: 1609 times
Been thanked: 4064 times
Yeah, I mucked up by bringing in serpentine belt adjuster info here
On my 1999, the timing belt tensioner is a 6mm hex key
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The 14mm head referred to is for the pulley not the tensioner arm. When the 14mm for the pulley was replaced a smaller torx T30 or 6mm hex was used but this is awkward to use.
The tensioner arm has always been T60. Also if you use the T60 you have room for the belt to be passed to the pulley from the front; hard to explain and you'll find out why.
Cookie-the-Swede
Year and Model: 2003 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 4 times
Post by Cookie-the-Swede »
I didn't have a T60 available so I used a T55. It worked fine.
ljsommar
Year and Model: v70 2002
Been thanked: 2 times
Post by ljsommar »
On my 2002 v70 the serpentine belt tensioner was definitely a hex bolt, a 14 mm. I had a hard time fitting in a ratchet with socket so I ordered a specialist tool from IPD. It is essentially a thin steel bar with a 12 point 14mm size bolt hole in it. I expected that I would be using it again when I did my second timing belt(this time including the serpentine tensioner) but no, now a T60 is used, which I had to borrow.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- If people look at the link at posted above....
* T60 is one option. You can find T60 in Home Depot, Lowes, Menards hardware store for $5.
* Other option is to pop the pulley's cover and you will see the 14-mm bolt:
a. Use 2-wrench trick as in the DIY I posted.
b. Buy the "serpentine belt tool" at harbor Freight for $15, this is basically a thin steel bar that allows access in tight space.
I use a 14 mm crow foot on a 18 inch 3/8 breaker bar, my “first crack “socket tool
There isn’t enough space on a 99’ for even a standard ratchet and socket, it’s pretty tight in there
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 26 Mar 2018, 05:50 I use a 14 mm crow foot on a 18 inch 3/8 breaker bar, my “first crack “socket tool
There isn't room for the T60 torx and ratchet either. I cut the tip off the torx bit, 1/8" !
It was either that or weld the bit to a bar.
One day I'll buy a proper tool. Til then...
Beat it to fit and paint it to match.
Post by cn90 »
- No need to cut any socket.
- Any Saturday shade-tree mechanic should get this serpentine belt tool. It is cheap ($16 at Harbor Freight).
This makes belt changing very easy...
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Just use a 14 mm box wrench. Ratcheting ones are especially nice. No specialty tools required.
erikv11 wrote: 27 Mar 2018, 12:44 Just use a 14 mm box wrench. Ratcheting ones are especially nice. No specialty tools required.
And two feet of stout pipe as an extender
