Yeah, I mucked up by bringing in serpentine belt adjuster info here
On my 1999, the timing belt tensioner is a 6mm hex key
Belt tensioner torx bit
- Been thanked: 4068 times
- Year and Model: Lots
- Been thanked: 128 times
The 14mm head referred to is for the pulley not the tensioner arm. When the 14mm for the pulley was replaced a smaller torx T30 or 6mm hex was used but this is awkward to use.
The tensioner arm has always been T60. Also if you use the T60 you have room for the belt to be passed to the pulley from the front; hard to explain and you'll find out why.
Cookie-the-Swede
- Year and Model: 2003 S60 2.5T AWD
- Been thanked: 4 times
I didn't have a T60 available so I used a T55. It worked fine.
ljsommar
- Year and Model: v70 2002
- Been thanked: 2 times
On my 2002 v70 the serpentine belt tensioner was definitely a hex bolt, a 14 mm. I had a hard time fitting in a ratchet with socket so I ordered a specialist tool from IPD. It is essentially a thin steel bar with a 12 point 14mm size bolt hole in it. I expected that I would be using it again when I did my second timing belt(this time including the serpentine tensioner) but no, now a T60 is used, which I had to borrow.
- Been thanked: 504 times
- If people look at the link at posted above....
* T60 is one option. You can find T60 in Home Depot, Lowes, Menards hardware store for $5.
* Other option is to pop the pulley's cover and you will see the 14-mm bolt:
a. Use 2-wrench trick as in the DIY I posted.
b. Buy the "serpentine belt tool" at harbor Freight for $15, this is basically a thin steel bar that allows access in tight space.
I use a 14 mm crow foot on a 18 inch 3/8 breaker bar, my “first crack “socket tool
There isn’t enough space on a 99’ for even a standard ratchet and socket, it’s pretty tight in there
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
There isn't room for the T60 torx and ratchet either. I cut the tip off the torx bit, 1/8" !abscate wrote: 26 Mar 2018, 05:50 I use a 14 mm crow foot on a 18 inch 3/8 breaker bar, my “first crack “socket tool
It was either that or weld the bit to a bar.
One day I'll buy a proper tool. Til then...
Beat it to fit and paint it to match.
- No need to cut any socket.
- Any Saturday shade-tree mechanic should get this serpentine belt tool. It is cheap ($16 at Harbor Freight).
This makes belt changing very easy...
- Has thanked: 311 times
- Been thanked: 817 times
Just use a 14 mm box wrench. Ratcheting ones are especially nice. No specialty tools required.
And two feet of stout pipe as an extendererikv11 wrote: 27 Mar 2018, 12:44 Just use a 14 mm box wrench. Ratcheting ones are especially nice. No specialty tools required.
- 1490 Views
- 14 Replies
- 1630 Views
Last post by Krons
- 10 Replies
- 2930 Views
Last post by dosbricks
- 308 Views
Last post by RedBrickCollector
- 2326 Views
