2000 volvo s70 non turbo possible etm?
- stargate476
- Year and Model: 2000 volvo s70
- Has thanked: 2 times
yea its why im tempted to just attempt the $39($31 +$8 core fee) one fromt he junkyard.. they got a 99 s70 , alot ive read said there is a high chance it works(assuming the etm is good int he first place) my goal is in a few months to just get a new one from xemodex and be done with this because this is seriously the only issue this car has. Yea this car has 186k miles on it and i think its the original etm tho i dont have the full service history
- Been thanked: 4064 times
On the second line of the ETM you will see a date code which will tell you if its original hardware..something like
00W39 - 2000 YEAR, week 39
If the label is white, you probably have the original - WELL DONE!
We had a discussion if the one from FCP (under $500) would work without software upgrades - Mike was sure it would but FCP hedged on it when I pushed them.
- stargate476
so semi related question which i think might be the reason its not starting now as opposed to the etm which may or may not be dying but looking at it today it is a yellow label unit so it was replaced at some point. Right now it will crank, start, then stall 1-2 second later. The only code that was showing is the P1670 code which i read is related to the security. Any ideas? would the attend ring being bad cause it to start then die after 1 second? tried both keys but neither work.
After you have the stall out, does it just crank without firing?
- stargate476
yea... then after a few minutes it will repeat.
Yeah, that’s the failure of the key to properly synch with the immobiliser
Described in detail here
viewtopic.php?f=1&t=81535&hilit=Ignition+sequence
- 781 Views
Last post by Ozark Lee
- 33 Replies
- 6243 Views
Last post by dubsetter
- 1765 Views
Last post by jmorman
- 2356 Views
Last post by truverman
- 2102 Views
Last post by precopster
